Results 1 to 7 of 7
Thread: Idle Timing?
    Default Idle Timing?
    Got this truck dialed in nice, except it rumbles and shakes the truck about every 15 seconds of idle. When you monitor with the flashscan you can see that the timing is flaring up to around 30 degrees down to about 10 during the rumble then it clears up for another 15 seconds. Any ideas on this, is this the idle spark flare up that is causing it or is it just something that we have to live with.
    Aaron.
    Aaron L.
    Conover, NC
    Never mind I think. I enable the spark smoothing for 800rpms and below and put +or- 15 degrees in there for idle only, with no VSS and it seems to have cleaned it up nicely. I don't know if this is something that everyone does or not. The truck doesn't make any power though. The owner of the truck had the cam installed at the local dealer and they did not degree it. Based on what the mechanic told me as to how he placed it in the truck I think it's 2 degrees retarded. That would kill the bottom end and on a truck, that's what you want. It only makes 200 to the wheels on a Hot Cam? Stock on my dyno will make between 213 and 222 same truck. Darn thing sounds good and idles great now though.
    Aaron.
    Aaron L.
    Conover, NC
    Default Re: Idle Timing?
    Quote Originally Posted by trudynosports
    Aaron.
    You can use the Bi-Directional controls to change your timing while idling and see if or how much added timing corrects it.
    2003 red vert
    Mods:
    LPE 100mm MAF
    RPM Level 6/4L60e trans
    3.42 gears
    Yank SS3600
    1-7/8" AR headers
    Z06 exhaust
    470rwhp 437rwtq
    Lifetime Member Scoota's Avatar
    Mar 2005
    Aaron.
    Aaron, I think you would agree, it's no good sounding good if the thing doesn't go.
    It's a lot easier to ask for forgiveness than it is to ask for permission.
    Exactly, the truck came to me with this cam already. I wouldn't have recommended this cam with no other mods, but that's beside the point. I was just wondering if anyone else has seen this same result.
    Aaron
    Aaron L.
    Conover, NC
    EFILive Distributor dfe1's Avatar
    Jan 2005
    I think you're looking at two problems relative to lack of power. The HOT cam really has too much duration for an engine with relatively low compression ratio and there's also a bit of incompatability between the cam's power range and air flow capacity of the heads, intake manifold and exhaust system. I've tuned a couple of vehicles with cams that weren't properly matched to the rest of the engine, and no matter what you do, you can't get any real power out of them. If you have the time and inclination, check the cranking compression and I'll bet you'll find it's a bunch lower than it should be. You may be able to help things a little by increase spark advance. Sometimes running "too much advance" in a situation like this will bring the power up, but that's an iffy deal- sometimes it helps, sometimes it doesn't.
    Thanks,
    I agree, just wanted to see what others had found in the similiar situations.
    Aaron.
    Aaron L.
    Conover, NC
  1. Idle timing tables
    By 1000HP in forum Duramax LLY
    Last Post: February 28th, 2011, 06:42 PM
  2. What is reasonable timing swing @ idle?
    By Chalky in forum Gen III V8 Specific
    Last Post: August 3rd, 2007, 02:46 AM
  3. Controlling idle timing.
    By Redline Motorsports in forum Gen IV V8 Specific
    Last Post: March 25th, 2007, 02:47 AM
  4. Idle tuning -- timing
    By heavyfoot in forum General (Petrol, Gas, Ethanol)
    Last Post: November 6th, 2006, 12:50 PM
  5. Idle timing and low compression
    Last Post: February 13th, 2006, 11:15 AM
