It all started doing a Ben map to dial in my VE table. my first pass with the Ben map was a normal adjustment 1 +/- 5%. I made the adjustments, went out to do a follow-up BEN and the next beN was showing lean again by 2 least 5% again. i had never observed this before. In my experience doing AutoVE, the changes are smaller with each pass up to a point when you start to overcompensate with changes. This was complicated by an intake change to a FAST90 and new LS2 TB. The intake did have a vacuum leak which i did find eventually along with caressing my new intake to get it to seal properly.
I just did another review of my EFILive install and spent about 45 minutes driving and creating another BEN Map. This one looks pretty good. I plan to do some extended driving tomorrow and see what the next BEN map looks like.
I can almost assure you that the error was mine. I am also hoping the problem is resolved. I'll update tomorrow.
