Results 1 to 7 of 7
Thread: Problem with speedometer
    Feb 2007
    Default Problem with speedometer
    Ok, first of, let me apologize if I've posted this in the wrong section.
    I have an 06 GTO, I'm trying to recalibrate my speedometer. I swapped the 3.46 gear for a 4.56. I have changed the following tables in my ECM and TCM, with no effect on the speedometer reading.
    ECM-
    H0101
    H0104
    H0103
    H0122
    H0125
    TCM-
    H0101
    H0103
    Also, all of the shiftpoints have been adjusted in the transmission according to the tutorial.
    I have changed these parameters from one extreme to the other and back again, I've been at this for several hours. There HAS to be something that I'm leaving out somewhere, because no matter what I change the values in the tables above to, the Reading is still 75MPH @ 2400RPM, when it should actually read betwen 50/60MPH.
    Please help me, as I only have a few hairs left to pull off before there's none left.
    Mike
    PS- I'll add that I'm also running the GEN IV 2bar OS. If it's of any consequence.
    Feb 2007
    anyone?
    Feb 2007
    ttt ttt
    There are issues with the speedo calculator.
    Some vehicle/controller combos are not supported by the speedo calculator. in the EFILive software. We are working on figuring out why some controllers do not respond as expected to changes in the calibrated values.
    We expect to have an improved speedo calculator in the next software update, which is due for public release before end of October.
    Feb 2007
    is there an alternative until then?
    Feb 2007
    resurrecting..
    I've just installed the latest release. As my car is in the shop getting a new transmission installed, I can't try to recalibrate it now. Has anything in the new release been changed that will enable me to fix the speedo?
    Quote Originally Posted by mrialsm4
    resurrecting..
    There have been improvements in the speedo calculator, however there is still this know problem: http://forum.efilive.com/showthread.php?t=7298
  1. From a M6 to 4L80 speedometer problem
    By RandyWS6 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 6th, 2009, 12:12 PM
  2. problem with the speedometer
    By odd boy in forum General (Petrol, Gas, Ethanol)
    Last Post: May 20th, 2008, 11:44 AM
  3. Speedometer Setting
    By lplott in forum General (Petrol, Gas, Ethanol)
    Last Post: November 30th, 2006, 03:56 PM
  4. Changing speedometer
    Last Post: August 9th, 2006, 04:20 AM
  5. Same OS different Speedometer Seg ID's
    By heavyfoot in forum General (Petrol, Gas, Ethanol)
    Last Post: April 28th, 2006, 02:02 PM
