Results 1 to 9 of 9
Thread: Analog input / CALC-PID
    Junior Member AWL INN's Avatar
    Jul 2007
    Default Analog input / CALC-PID
    Hey all, I'm looking for a pressure transducer so I can log fuel pressure using the analog 1-5 volt input on the black box. Has anyone here used the analog input with a pressure sensor? I have been stumbling through the calc._PID to change the 1-5 volt single to a PSI but still having problems with understanding how to edit the calc.text script. Any help would be great!!! Thank you for any input!! Brett~
    Jul 2007
    YES! thankyou! I fixed the PID from this tutorial and there it said they were using Autometer's 2246 pressure sending unit. Thanx again! Brett~
    Jul 2007
    I found an error in the Tutorial in their math on the calc_pids.text in my setup anyway. The math they had setup was ({EXT.AD1}*25)-12.5 If the sensor is 1-5 volt and 1=0 and 5=100 this wont work right. 1x25=25-12.5=12.5 so 1volt would = 12.5 psi. and 5volts would +112.5 psi
    Ok this is what I came up with an it works right for me.
    PSI 0 100 .2 {EXT.AD1}*100/4-25
    1v x100 = 100 /4 =25 - 25 =0psi
    5v x 100= 500 /4 =125 -25 = 100psi
    It seems to work perfect so I'm not sure what I did different that the Tutorial wouldn't work right. Just food for thought I hope this helps someone else on setting up the analog input. Brett~
    Jan 2004
    Brett
    Thanks for letting us know.
    I came up with this after you pointed out the error "({EXT.AD1}*20)"
    Andy
    Jul 2007
    Quote Originally Posted by acsf
    Brett
    Andy
    Andy,
    I still think that if you use ext.ad1 x 20 will not be accurate.
    The sending unit will out put a range of 1-5 volts (if the out put is zero then something has failed) so 1volt would be 0 psi and 5 volts would be 100 psi at least on the sending unit I have (autometer) In your calc 1 volt would equal 20 psi when the pressure is accually 0. 5volts would be 100psi though.
    The way around this is to take out the 1v offset and use a 4 volt range instead of a 5 volt range. For some reason EFILive didn't like the first calc I tried witch on paper works correcty. {EXT.AD1} -1/4x100 Im not sure why but wording it this way worked. {EXT.AD1} x100/4-25 It tracks my analog guage within a pound +/-. I hope this makes sense. Brett~
    Sep 2003
    I think your first calculation didn't work because you are missing a set of brackets.
    Try: ({EXT.AD1} - 1) * 25
    Jan 2005
    Welcome to the forum Brett. Sounds like you're off to a great start.
    What sending unit are you using?
    When Beer99c5 and I were working on this, we both spoke with Autometer and they stated the 2246 had a 0-5vdc output range. Just want to make sure the tutorial is correct.
    Jul 2007
    Yeah, I was wrong. It is working from 0-5 volts. Now it's correct. I must have been smoken crack Thank you guys for the help. On a brighter note. I entered a Dyno contest last weekend. I made 594.2 RWHP with my EFILive tuned Duramax. Tune made by me and help from you guys. Brett~
  1. Replies: 4
    Last Post: April 22nd, 2009, 04:50 AM
  2. V2 analog input ground configuration.
    By mistermike in forum FlashScan V2
    Last Post: June 15th, 2007, 02:37 AM
  3. need analog input spec
    By foznoz in forum General (Petrol, Gas, Ethanol)
    Last Post: March 5th, 2007, 03:46 PM
  4. FJO Analog Input AFR PID
    By heavyfoot in forum External A/D inputs
    Last Post: August 14th, 2006, 10:11 AM
  5. FJO Analog Input AFR PID
    By heavyfoot in forum General (Petrol, Gas, Ethanol)
    Last Post: July 15th, 2006, 04:26 AM
