Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: 4L60E to 4L80E swap
    Jan 2007
    Default 4L60E to 4L80E swap
    Hi guys,
    been donkeys since I was here last.
    Went to the States in July. One week after my return I blew up the 60E.
    Decided to do the swap to the 80E...apparently no one has done this before in the OBS 4x4 5.7L Suburban.
    Anyway...imported a trany from PA and rebuilt it...just for the hell of it...and the experience
    Now I'm having a look at my tune and I'm wondering how I go about making the changes.
    Do I just copy ever table from a tune of a vehicle with an 80E?
    I looked in Holden Crazy and couldn't find anything running a 411 PCM and 5.7L with 4L80E.
    Lextech sent me a copy of his TT truck tune and I just copied and pasted every table accross..is that right? He's using COS5 and I'm using COS3.
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
    Lifetime Member Doc's Avatar
    Oct 2005
    You need to do the tranny segment swap. There is a 02 Silveado 6.0l that has the 80e on HoldenCrazy.
    www.efialchemy.com
    www.greatamericancarwar.com
    Sep 2005
    It doesn't matter what the motor is in the tune you find, it just needs to have the 80 and be the same operating system#. Then just do a trans segment swap and you should be good.
    Dec 2005
    Hey Howard,
    You also have to move around a couple of pcm pins that go to the Big trans connector...Lextech probably already gave you that info, but if not let me know and I'll send you the schematics.
    98 Chevy truck RCSBFS 2wd/5.7L/4L60E:drive:/Paxton Novi 2000 S/C @ 7psi / Megasquirt
    72 Chevelle LQ9/4L80E/GT42 conversion in the works
    http://www.ls1tech.com/forums/showthread.php?t=449129
    Jan 2007
    Thanks guys...yeah I have the wiring diagrams and that's easy enough.
    I was more concerned with the tune side of it.
    As I'm running Cos3, how do I do it?
    Howard
    DUCT TAPE.
    Dec 2005
    Are you using COS3 for an '01 or '02 PCM?
    Jan 2007
    COS3 for the 99+ with the 2001 Express van base.
    I just made the segment swap using the file for the Silverado as Doc suggested.
    Seemed to work fine.
    Can someone please check this for me?
    Howard
    Howard
    DUCT TAPE.
    Sep 2005
    The real test will be when you flash it in, if the truck runs and drives :lol:
    Jan 2007
    Why has the boost VE table gpone to all 500 since the segment swap?
    Howard
    DUCT TAPE.
    Dec 2005
    That's weird, you should do a comparision with your old file and make sure all the engine parameters are where they should be. Sounds like it worked for the most part.
  1. 4L80E swap into 2006 6.0L truck with 4L60E
    By powermonger in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: May 19th, 2010, 03:59 AM
  2. Using a 4L80E in a 4L60E car..
    By Redline Motorsports in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 12th, 2009, 05:03 PM
  3. 4L80E swap
    By grec-O-face in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: August 3rd, 2008, 01:36 AM
  4. 4l60e ---> 4l80e What changes ?
    By Tydriver in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: March 2nd, 2006, 02:40 PM
  5. 4L60E conversion to 4l80E 2002 Camaro
    By 94SS in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: November 21st, 2005, 12:04 PM
