Results 11 to 20 of 25
Thread: 4L60E to 4L80E swap
    Jan 2007
    Seems all the COS tables are different.
    Comparison summary: 04:02:50 pm, Monday Sep 24, 2007
    Calibration comparison between Current tune as of 180707.tun and Current tune as of 180707_trany swap.tun.
    *Values that differ by more than 0.100000% are considered different.
    A0000 "Forced Octane Scaler" N/A "CAL: Disable <-> ALT: 255"
    A0001 "Forced Octane Scaler Percentage" 1499.9756 "CAL: 100 <-> ALT: 1600"
    A0002 "Octane Scaler Limiter" 1499.9756 "CAL: 100 <-> ALT: 1600"
    A0009 "Boost VE Table" 83.4945 "Different from cell: 0,0 to cell: 18,19 inclusive."
    A0014 "IAT VE Multiplier" 2999.9509 "Different from row 0 to row 18 inclusive."
    A0010 "Boost Timing Table" 6399.9023 "Different from row 0 to row 18 inclusive."
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
    Dec 2005
    I just did the same thing and got the same results.
    Took my COS 02020003 file and did a Trans Calibration and Diagnostic segment swap and all my COS tables and parameters went to flat values.
    I would think that if you just copy all of that over from your old file and do a full flash with the new file, you should be good to run. Weird though.
    98 Chevy truck RCSBFS 2wd/5.7L/4L60E:drive:/Paxton Novi 2000 S/C @ 7psi / Megasquirt
    72 Chevelle LQ9/4L80E/GT42 conversion in the works
    http://www.ls1tech.com/forums/showthread.php?t=449129
    Jan 2007
    Thanks Max,
    Must be something to do with it being a COS.
    I'll PM Paul and see what he thinks.
    Howard
    DUCT TAPE.
    The EFILive custom calibrations are allocated in segment 0. So to transfer custom calibrations you need to copy segment 0.
    Even though segment 0 is called the "operating system", copying segment 0 does not copy the operating system, it only copies EFILive custom calibrations.
    Jan 2007
    Sorry Paul...you lost me!
    I just copied the trany tables to my tune and as I did my COS tables all changed.
    Howard
    DUCT TAPE.
    Aug 2006
    Hey Howard,
    I am using COS3 not 5. My tune should flash right into your truck.
    G'day Howard,
    Are you saying you copied only the trans segment from a 4L80E file to your COS3 file, and the custom cals are now different...?
    Joe
    Jan 2007
    Yes Joe...thats exactly what happened.
    Here's the two tunes...before and after.
    Thanks Jeff....I didn't realize that.
    Howard
    Howard
    DUCT TAPE.
  9. #19
    It should not do that - I'm looking into it.
  10. #20
    Jan 2007
    Thanks Paul. This is why I like this forum so much...it's also why my JET DST hasn't seen the light of day in a long time!
    Howard
    DUCT TAPE.
  1. 4L80E swap into 2006 6.0L truck with 4L60E
    By powermonger in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: May 19th, 2010, 03:59 AM
  2. Using a 4L80E in a 4L60E car..
    By Redline Motorsports in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 12th, 2009, 05:03 PM
  3. 4L80E swap
    By grec-O-face in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: August 3rd, 2008, 01:36 AM
  4. 4l60e ---> 4l80e What changes ?
    By Tydriver in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: March 2nd, 2006, 02:40 PM
  5. 4L60E conversion to 4l80E 2002 Camaro
    By 94SS in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: November 21st, 2005, 12:04 PM
