Results 1 to 10 of 11
Thread: Scan Data vs Tune maps? HELP
    Aug 2007
    Default Scan Data vs Tune maps? HELP
    Hi all,
    A few issues im having on trying to tune 2 different LS engines are as follows...
    1. Logged data with scanner never seems to be accurate with vehicle conditions. example.... Load tested vehicle on dyno to measure afr, on the ve table im viewing the load never exceeds 20 kpa on the table.
    2. IPWV table shows the vehicle to be running at 4.5 volts at all times. The map side of this table changes but the voltage scale is constant at 4.5. On previous vehicle it was fixed at 7.5 volts.
    3. Measured 140kpa on dyno and 20 kpa measured on logged data.
    What am I doing wrong?
    Thanks in advance,
    Chris
    Wichita Dyno LLC
    www.wichitadyno.com
    EFILive Reseller kbracing96's Avatar
    Sep 2005
    Chris, sound like you need to change the unit of meause in the scan tool. Press F8 or click the PID tab. Then right click on the PID in question, and change it form Imperal to Metric. Then it will track in metric in the tune.
    Aug 2007
    Ive tried both ways, logging in Metric and Imperial. Either way ive made sure what im logging and what im viewing are in the same units of measure. That doesnt explain the low voltages readings its using in the injector tables though...
    Thanks for the input though. Any other ideas?
    Sep 2005
    Hum.. can you post a log and the tune, and I'll try it with mine?
    Aug 2007
    Let me know if this works, you can also call me or vise versa. Chris
    Aug 2007
    Im glad im not alone. Im thinking about purchasing a new lap top thinking that might be the issue. But if I have a software problem that would be a worthless purchase at this point. Granted the tune is no where near close that is posted but I am guessing when it comes to the tune since the logged data is not correct with actual tables used.
    Aug 2007
    Default Ok, this is weird
    There was a post on here a second ago...now its gone? Anyone care to help with this issue with the software? Chris
    From scantool, do these steps:
    1. set Edit->Properties->Options->Preferred Unit System to Metric; click OK.
    2. from PIDs F8 tab, right click on MAP, select Metric.
    3. from Data F9 tab, verify MAP has units kPa.
    Exit scantool, restart scantool, verify step 3.
    Sep 2005
    Ya, something dosen't look right. Do you have the most current software from here?
    http://www.efilive.com/download.aspx
    Also, are you using a V1 or V2? If you have a V2, make sure you have that latest software and also it is important you upgrade the firm ware in the V2 unit it's self. But some thing is wrong with your MAP reading.
    Yep, something is weird, your SPARKADV is around -35* to -40*...
    Did you enter the correct VIN/OS and PCm type...?
    If using V1, are you blackbox logging...?
    Are you running boost...?
    Has the MAP sensor been tested...?
  1. No live data on EFI scan tool
    By Drummer in forum FlashScan V2
    Last Post: February 17th, 2008, 11:05 PM
  2. Linking Scan Log To Tune File Maps
    By The Alchemist in forum E37, E38 & E67 PFI ECM's
    Last Post: July 30th, 2007, 05:33 PM
  3. Problem with Trailblazer scan data.
    By Redline Motorsports in forum Gen IV V8 Specific
    Last Post: February 1st, 2007, 10:25 AM
  4. Converting Scan data
    By NewV in forum General (Petrol, Gas, Ethanol)
    Last Post: December 8th, 2006, 09:41 AM
  5. linking scan data to tune file
    By a78turbo in forum Duramax LLY
    Last Post: March 14th, 2006, 03:53 PM
