Results 1 to 6 of 6
Thread: Intake valve temp -40
    Aug 2007
    Default Intake valve temp -40
    When I scan intake valve temp all I get is -40. I'm using an e38 and l76 with a Speartech loom and original tune supplied in the ECU. The vehicle was going into PE and had AFRs around 10:1, the only way I seemed to be able to get some satisfaction was to zero out all the open loop tables B0141 and B0146 and set PE only. I thought this could be due to the -40 intake valve temp as scanned looking up B0141 and B0146.
    With B3618 commanded fuel says it is a commanded lambda yet it behaives like an EQ table where I command 1.12 and get AFR of 12.8?
    Interested in thoughts, have the vehicle for a couple of days
    Aug 2007
    I've since found the tune supplied was for an LY6. Are there sensors under the manifold for intake valve temp or is it a derived figure from intake air and coolant?
    I don't recall the exact calculation but yes it is calculated not measured.
    I presume in the conversion all the various sensors are hooked in? IAT specifically?
    Aug 2007
    IAT is there, there is also a plug at the back of the manifold in the valley that I was told was for variable displacement(by Holden), but not yet used. I have an L76, the E38 was supplied with a LY6 tune from Speartech, I've managed to get satisfactory tune by manipulating injector flow but am looking forward to the upgrade with calculated VE tables as I know its a bit crude.
    Also it dosent seem to go into PE under about 60% throttle regardless of what settings I use?
    Thanks for the response.
    Lifetime Member eboggs_jkvl's Avatar
    Apr 2004
    I got an error reading of -40 on something (it may have been IAT) that was due to the speed that I was scanning and the "update" frequency on the Properties/playback settings. This is probably NOT your issue but the -40 rang a bell down (or up if you're in Oz) here in Florida.
    Aug 2007
    I changed the tables with intake valve temp and there was no effect on the tune at all, I can only assume they are not used in this callibration.
  1. Valve Cover Vents and PVC
    By Rusty in forum Gen III V8 Specific
    Last Post: March 6th, 2009, 11:25 AM
  2. inlet valve temp - dma pid not working
    By hymey in forum FlashScan V2 BB Logging
    Last Post: April 14th, 2008, 12:37 PM
  3. Varable Valve timing for L92 6.2L
    By 02Z06 in forum E37, E38 & E67 PFI ECM's
    Last Post: June 28th, 2007, 11:54 AM
  4. Programming the Intake Air Valve for a Positive Air Shutdown
    By jpgmtech in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: June 20th, 2007, 01:38 AM
  5. Valve Bounce identification logging
    By oztracktuning in forum General (Petrol, Gas, Ethanol)
    Last Post: June 1st, 2007, 01:01 AM
