According to the document, C3XX pickups will feature a new 'Gen V' 6.2-liter dual overhead cam (DOHC) V8 engine - a major departure from GM's traditional overhead valve (OHV) pushrod engine design used in its trucks, like the ‘Gen IV’ 403-horsepower / 417 lb-feet L92 6.2-liter V8 under the hood of the GMC Sierra Denali. The only DOHC V8 GM currently offers is Cadillac’s 4.6-liter Northstar engine.
The Gen V 6.2 motor will use variable valve timing (VVT) like the Gen IV 6.2, but the use of dual overhead cams holds the promise of four valves per cylinder instead of the current two valves, for better intake and exhaust flow and increased power. This is a similar setup to the 5.7-liter i-Force V8 used in the Toyota Tundra, but the Gen V 6.2 will also offer GM's active fuel management (AFM) system. AFM shuts down half the cylinders during steady state running for improved fuel economy – a feature not currently available for the i-Force. Up until this point, it’s been conventional wisdom that implementing cylinder deactivation on OHC engines is impractical for reasons of cost and complexity.
Pushrod engines won’t be disappearing entirely from GM’s truck line. A new ‘Gen V’ OHV V8 will replace the current 320-hp / 340 lb-feet 5.3-liter V8. Apparently the final displacement hasn’t been determined yet, because it’s referred to as 5X.
The new 5X gasoline engine will feature spark ignition direct injection (SIDI), similar to a diesel's fuel injection setup but still using a spark plug to ignite the fuel instead of diesel's high compression ratio that causes the fuel air mixture to auto-ignite. SIDI places the fuel injector right inside the combustion chamber, so fuel can be directly mixed with air entering the chamber during the intake stroke instead of before it enters the chamber, like in a conventional multi-port fuel injected gas engine. This approach enables a leaner burn of the fuel at higher compression ratios than current gas engines, resulting in greater fuel economy, cleaner emissions, and more power.
Initial production of both engines is slated to start in 2011 with full production in 2012.
Of course, it's possible that because this information is still approximately three years out in time, plans detailed in this document for the full size truck powertrains could still change.
http://www.pickuptruck.com/html/news...eunionuaw.html
