Results 1 to 4 of 4
Thread: Problem reading PCM
    Sep 2007
    Default Problem reading PCM
    I have an LMM that I am having problems reading the PCM on. I have installed all of the latest updates and uninstalled and reinstalled the software. After I get the 512k read an error message reads: 'Error cannot merge calibrations with operating system file c:\Program Files\EFIlive\V7\configuration\m81.bin'. I then click ok and turn my ignition off for the countdown and after the 15 secs another error comes up that says 'Range Chech Error'. I talked to guy at Socal earlier today and he sent me some files to copy into a folder in efi buy it still did the same thing. I tried to get ahold of him again today to tell him it didn't work but he must either be closed or busy. Anyone else have any ideas?
    As part of your software update did you also update the firmware in the V2 hardware?
    EFILive Distributor Trippin's Avatar
    May 2004
    It was a 2008. He needed the M81.bin
    www.socaldiesel.com
    EFILive-DSP5......Switch your Attitude!
    EFILive-CSP5......The Smart Way To Switch Your Cummins Tunes!
    EFILive-DSP4......Switch Your Colorado and Canyon Too!
    Sep 2007
    Thanks again Guy for the great customer service. I made the right choice in choosing you for my purchase.
  1. reading Problem ( LC-1 logwork & gage & EFIlive )
    By Ls1_Rulz in forum FlashScan V2
    Last Post: October 17th, 2008, 06:42 AM
  2. problem reading allison 6 speed TCM
    By Samdogmx in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: July 5th, 2007, 12:00 PM
  3. Reading an E38 / E67 ECM
    By GMPX in forum E37, E38 & E67 PFI ECM's
    Last Post: June 6th, 2007, 07:02 PM
  4. Reading the P12 PCM
    By GMPX in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: March 18th, 2007, 10:48 PM
  5. Problem reading the PCM!!!Help Please!!!!
    By Earl H in forum General (Petrol, Gas, Ethanol)
    Last Post: January 16th, 2005, 09:15 AM
