Hi there Guys, I have a 2003 VY Holden that I have fitted a 232 232deg .600 .600 cam, double valve springs, 80mm throttle body over the radiator intake, headers and mafless tune, the first problem was the new Capa OTRCAI was not up to the job at WOT the map was around 88-92, once I removed the filter it was back up to 100 so a better intake is on the cards.
My main problem is that when on the dyno ever time it reaches 6250rpm there is a massive loss in power that then picks back up just before the limiter at 6650rpm, at the same time as the power loss (spot on 6250rpm) the knock sensors pick up and set knock retard to around 1.5 deg this happens regardless of timing I have tried anywhere from 12 to 28 deg (locked timing) and there is absolutely no knock at all until exactly 6250rpm ever time which makes me think its false knock, I have also tried any where from 11.25 to 13.1 a/f ratio with no change in the dip in power and the knock still kicks in at 6250 ( the injector duty does not go over 88%). The VE map is dialled in burst knock of ect ect. I’m staring to think it may be mechanical such as valve train float that is then setting off the knock sensors, has any one seen this problem before as im really starting to pull my hair out.
Thanks in advance for any help on this matter.
