Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Guys that are tuning the 4cly, come in please :)
  1. #11
    I still want to disable COT in my P10, the P11 files Ive looked at are IDENTICAL in table structure so Im guessing the behind-the-scenes code is similar as well.
  2. #12
    Aug 2008
    All I want, is to be able to put tune into Open Loop for Big Cammed Motor or Big Turbo...
    FLASHSCAN V2 & AUTOCAL
  3. #13
    May 2010
    You still arent able to tune for boost with this ecm, since it is alpha-n. Although ive been turbocharged for a while and it works ok but definately not right.However Ive pretty much confirmed the 2000 LD9 2.4 cavalier supercharger tune can be flashed into this pcm. Ive been searching like crazy for it. Their are quite a few but they are HPtuners files. Does anybody know someone who might have read this pcm with efilive? Im dying for it. Gameover why do you need to put it in open loop for a turbo or a cam?
    1997 S10, 06 trailblazer SS LS2 swap, 4L70E trans, 76mm turbo. Factory ZQ8 suspension. 3.08, G80 w/a zexel. With a 0411 swap.
  4. #14
    Aug 2008
    The guy I'm doing the harness's & ecu for doesn't want to run O2 sensor's...It's basically Off-road Only...
    I don't know why, but they are accustomed to the Delphi ECU & harness's
  5. #15
    May 2010
    If you left the o2 unplugged wouldnt it run open loop? Not sure if it would run in limp or reduced power mode or something.
  6. #16
    Aug 2008
    Quote Originally Posted by slows10 View Post
    Thats what im trying to figure out...
  7. #17
    May 2010
    It will for sure run in open loop with 02 sensor unplugged,ive tried it. It also seem to run fine. But the cel obviously comes on. I just havent tried it in a while and cant remember if it does something like run on the low octane spark map or something. I doubt it does.
  1. Official dump in unsupported 4cly tunes you read out thread.
    By wait4me in forum IL4, 97-01 PCM and 02+ P11 PCM
    Last Post: November 18th, 2011, 04:39 AM
  2. Guys I Need Help!
    By 99STEPSIDE in forum Gen III V8 Specific
    Last Post: February 24th, 2009, 03:57 AM
  3. To the EFILive Guys: Additional Make Model Tuning
    By TAQuickness in forum General (Petrol, Gas, Ethanol)
    Last Post: January 4th, 2006, 12:18 PM
  4. You guys are the best...
    By Drake in forum General (Petrol, Gas, Ethanol)
    Last Post: February 12th, 2004, 04:26 PM
