I have an LS1/T56 with the wiring harness and computer from a 2004 GTO in my car. I pulled the stock tune, and the current OS is 12587604. Looking through as much information as I could, I decided that I would like to use COS#5. But now that I'm looking more into COS#5, it looks like there isn't a 1MB COS#5 out there.
From the chart, it appears as if I need to use a COS with the numbers 041100XX. A speed density tune is an absolute must, as I have a dual 3.5" intake, so no MAF sensor.
If COS#5 is not available, what is my best alternative? Is there a COS#3 that I could use given the current OS in my GTO PCM? If COS#3 is availabe, would I be able to upgrade to COS#5 if/when it becomes available?
Thanks,
Kevin
