I'm considering moving to CO3 once I have my tune sorted out. I understand that the ve table switches from rpm vs map to ect vs map. Is this so and if so will it need me to redo my ve table?
I'm planning the move to possibly go semi open loop so I can ditch the ltft and just run commanded on all but where I call for 14.7 (probably just the idle cells). I know the os is noted for SD but as I plan to do some cross alp passes I was hoping to run the MAF.
Will CO3 work well with the MAF?
