05 LLY
I bought efi from socal diesel. Had the tow tune hooked up, works AWESOME. I got the 06 intake... modified... reset MAF tables to what GM resets them to. I also messed with the turbo below 1000 rpm so i could have more LB7 Noise. I go for a drive and my boost gauge will spool up to 15 psi but the truck goes nowhere... foot to the floor. Was i supposed to make changes elsewhere when i redid the MAF? Was i supposed to add or remove fuel when i made turbo changes? I only modified below 1000 RPM's so i am assuming i am having an issue with the new MAF table. Any input is greatly appreciated.
