I'm sorry Robert, I just saw this.
The first thing you need to do is go to Program Files->EFILive->V7->Configuration and open text document sae_generic.
Then click "Edit" and "Find..." (or hit Ctrl+F) and type SAE.FRP_C in the search window.
There should be several columns of data labeled Paramater, PRN, SLOT, Units, etc.
Under units you will need to change "kPa" to "MPa".
You will then need to search for the SLOT number. On mine it is UNM-16-908. On mine it is also above where you just were so in the direction part of the search window you will need to select Up.
When you find the SLOT you will see kPa and psi. Once again change "kPa" to "MPa".
I then changed the column labeled "Factor" from "10.0" to ".01". That should get you fixed up.
