Results 1 to 4 of 4
Thread: ECM Lock and unlock
    Oct 2007
    Default ECM Lock and unlock
    Does GM have a lock on any ECM's from the factory? I have one showing locked.
    Yes, all ECMs are locked from GM. EFILive has to crack this code in order to send the bootloader to the ECM so it can be read/flashed. Now if EFILive cant crack this one, sounds like someone else has changed the lock code and either you need to know what it is in EFILive, or have that person unlock it for you. I dont think EFILive can unlock HPT locks and vice-versa.
    Our latest pre-release software has an option that tries 2 additional GM keys. Sometimes (but rarely) controllers can get sent into the field with the keys set to "production line" settings. EFILive now allows you to "try" those keys as well. To try them, use the option "Try Alt Keys" in the PCM locking window.
    But what Erik said about the locking is all true. We can't unlock any other tuners' locked controllers and they can't unlock ours. (unless you remove/replace the flash chip).
    Oct 2007
    Default Ecm Lock
    Will tech II reset lock so efi can unlock it?
  1. How can I unlock a PCM
    By imtduncan in forum Gen III V8 Specific
    Last Post: February 19th, 2009, 08:12 PM
  2. Can't unlock pcm
    By red12secz28 in forum Duramax LB7
    Last Post: November 30th, 2007, 02:29 AM
  3. How do I unlock the PCM?
    By -=Mod=- in forum General (Petrol, Gas, Ethanol)
    Last Post: April 28th, 2007, 12:06 PM
  4. Unlock the PCM
    By ASSAMI in forum RoadRunner Real-Time PCM Emulator
    Last Post: February 15th, 2007, 05:49 AM
  5. TCC Unlock Problems
    By Rontune in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: June 7th, 2006, 09:46 AM
