Results 1 to 7 of 7
Thread: Aftermarket tach problems
    Jul 2006
    Default Aftermarket tach problems
    Anyone tried to hook up an aftermarket tach from the pcm output signal?
    I have an 04 GTO engine and pcm in a 1989 chevy truck (about 500 ponies) The tach will not read pcm output signal and I have tried changing it to 12 volt and still no response. It does pulse my led tester though. Any clues why???
    Lifetime Member Biggsy's Avatar
    Jan 2007
    Most output signals are a relatively "clean" pulse and are not enough to trigger some after market tach's (they like bigger, sharper pulses, eg in the EFILIVE logo)
    I have made an interface that takes the clean signal and use it to trigger a mini coil on a circuit board using a transistor. (like a mini coil and points setup)
    The output will fire most (if not all) aftermarket tacho's.
    Dave.
    Jul 2006
    I thought about doing that also, I was hoping I was just missing something in the pcm setup. I am already on it.
    Jan 2007
    have a look at this. I have not had a chance to get the resistor yet but it sounds like it works.
    http://www.ls1tech.com/forums/showthread.php?t=544193
    Feb 2007
    I had to wire my tach in 4 cylinder configuration
    Lifetime Member eboggs_jkvl's Avatar
    Apr 2004
    Quote Originally Posted by cliffy v
    That would be my first question. The LS engine needs to be set for aftermarket tachs as a 4 banger.
    2014 Corvette Convertible, Torch Red, A6, Z51, 3LT, NPP Exhaust
    Aug 2004
    If you call the manufacturer of your gauge, they will be able to get you the converter you need to make it work.
    Sometimes you can make it work by changing the tach pull up selection in the system tab on efilive.
  1. Replies: 65
    Last Post: January 18th, 2010, 12:58 AM
  2. S10 ZR2 and Tach
    By ZR2_350 in forum Vortec V6/V8 Specific
    Last Post: June 17th, 2009, 06:40 AM
  3. E38 Tach
    By minytrker in forum E37, E38 & E67 PFI ECM's
    Last Post: June 11th, 2009, 05:50 PM
  4. GM to crack down on Aftermarket calibrated vehicles?
    By DrkPhx in forum General (Petrol, Gas, Ethanol)
    Last Post: March 28th, 2008, 03:15 PM
  5. Aftermarket MAF's and tuning..
    By Redline Motorsports in forum General (Petrol, Gas, Ethanol)
    Last Post: March 18th, 2006, 02:06 PM
