Results 21 to 30 of 42
Thread: licensing a used roadrunner
  1. #21
    Oct 2004
    The license does relate to both the FlashScan and RoadRunner serial numbers. Also if you purchased the unit from another user we like to unlink the RoadRunner from their FlashScan SN.
    Andrew
    EFILive Crew
  2. #22
    Lifetime Member johnv's Avatar
    Jan 2005
    Good to no,
    I have just bought a used roadrunner, should have it next week,
    Hopefully it comes with all the info i need to transfer licience to my V2.
    Back yard boost
    347+ T76 = 770 rwhp 10.96 @ 135 mph
  3. #23
    Quote Originally Posted by vxchev8 View Post
    Okay, I did read post 14
    I just wanted to short cut the process as I guess EFIlive my have some sort of cross referencing system between flaschcan units and roadrunner serial numbers issued by them i.e they have the details already recorded.
    Do you know if they do, mr prick?. Or is it more complex then that?
    Yes we have a record of the RR license, but we need you to send us the FlashScan Serial number and the RR Serial number and the matching registration key from the original owner to prove that the original owner has authorized you to have/use the unit.
  4. #24
    thanks for the replies
    Once I have the RR linked to my FlashScan, can I then send through my mates information ( and mine) to allow him to use the roadrunner?. Do I lose access? Or does my FlashScan stayed licenced to my roadrunner forever.?
  5. #25
    Nov 2006
    He can use it with your license info.
    Keep in mind the license is what secures the hardware.
    LC-1 WBO2
  6. #26
    Sorry I should of added in the distance, mate is about 3430k's away . Can roadrunner be linked to 2 different V1's at once.
  7. #27
    Nov 2006
    He can use it with your license and his V1.
    LC-1 WBO2
  8. #28
    Many thanks to Paul for getting me started with the roadrunner licence.
    EFILive support is just fantastic.
    Thanks mr.prick for your replies.
  9. #29
    Yes it is!
  10. #30
    I just picked an RR.
  1. Licensing
    By kistlerjm9 in forum Gen III V8 Specific
    Last Post: August 5th, 2009, 12:13 PM
  2. Licensing?
    By Mort in forum General (Petrol, Gas, Ethanol)
    Last Post: August 3rd, 2009, 03:06 AM
  3. Need help licensing my PCM
    By Snakeaterz06 in forum General (Petrol, Gas, Ethanol)
    Last Post: May 10th, 2009, 07:58 AM
  4. Licensing
    By Biggsy in forum FlashScan V2
    Last Post: February 6th, 2007, 02:14 AM
