Results 1 to 9 of 9
Thread: '99 VS Series III SS Ute and EFILive V4
    Oct 2007
    Question '99 VS Series III SS Ute and EFILive V4
    Can't seem to get any thing working with EFILive V4 on vehicle.
    Try both VS and VT files but neither seem to be successful, can some one help?
    Thanx
    Jasun
    Oct 2004
    Are you getting a vehicle connection? What cable are you using and what baud rate?
    Andrew
    EFILive Crew
    Oct 2007
    The baud rate is 8192 and the cable is a usb to 16 pin connector,
    If I use the gmh-vt8 file I receive the following:
    08:26.686: Check vehicle interface...
    08:26.694: Waiting for Aldl bus silence of at least 10ms...
    08:26.696: Requesting Max232 interface to acknowlege: $FF,$55,$AC...
    08:26.706: Max232 interface detected OK
    08:26.707: Scanning for heartbeat and chatter frames...
    08:26.707: Waiting for Aldl bus silence of at least 10ms...
    08:26.816: Com timeout: Expecting frame header byte
    08:26.825: No chatter found
    08:28.519: Start macro: Engine data and DTCs: DATADTC
    08:28.520: Synchronising ALDL communications...
    08:28.520: Waiting for heartbeat: $08,$55,$A3
    08:28.520: Waiting for Aldl bus silence of at least 10ms...
    08:28.628: Com timeout: Expecting frame header byte
    08:28.633: Synchronising ALDL communications...
    08:28.633: Waiting for heartbeat: $08,$55,$A3
    08:28.633: Waiting for Aldl bus silence of at least 10ms...
    08:28.738: Com timeout: Expecting frame header byte
    08:28.744: Synchronising ALDL communications...
    08:28.744: Waiting for heartbeat: $08,$55,$A3
    08:28.744: Waiting for Aldl bus silence of at least 10ms...
    08:28.849: Com timeout: Expecting frame header byte
    08:28.857: Stop macro: Engine data and DTCs: DATADTC
    and the gmh-vr68vs8 file gives:
    09:02.009: Opening COM2 8228,8,N,1
    09:06.111: Check vehicle interface...
    09:06.119: Waiting for Aldl bus silence of at least 65ms...
    09:06.183: Requesting Max232 interface to acknowlege: $FF,$55,$AC...
    09:06.194: Max232 interface detected OK
    09:06.195: Scanning for heartbeat and chatter frames...
    09:06.195: Waiting for Aldl bus silence of at least 65ms...
    09:06.492: Com timeout: Expecting frame header byte
    09:06.516: No chatter found
    09:25.513: Start macro: ECM Engine Data: Engine Data Table0
    09:25.512: Send: $F4,$57,$01,$00,$B4
    09:25.732: Com timeout: Expecting frame header byte
    09:25.743: Send: $F4,$57,$01,$00,$B4
    09:25.963: Com timeout: Expecting frame header byte
    09:25.973: Send: $F4,$57,$01,$00,$B4
    09:26.193: Com timeout: Expecting frame header byte
    09:26.207: Stop macro: ECM Engine Data: Engine Data Table0
    Thanx,
    Jason
    Oct 2004
    The VS file is likely to be the correct one. I've seen suggestions previously about reducing the T6 timeout to 10ms - from the current value of 65ms.
    Perhaps try that and advise the results.
    Andrew
    EFILive Crew
    Oct 2007
    Unhappy
    Changed T6 to 10ms and received:
    12:36.056: Opening COM2 8228,8,N,1
    12:46.436: Check vehicle interface...
    12:46.444: Waiting for Aldl bus silence of at least 10ms...
    12:46.453: Requesting Max232 interface to acknowlege: $FF,$55,$AC...
    12:46.464: Max232 interface detected OK
    12:46.465: Scanning for heartbeat and chatter frames...
    12:46.465: Waiting for Aldl bus silence of at least 10ms...
    12:46.675: Com timeout: Expecting frame header byte
    12:46.685: No chatter found
    13:00.976: Start macro: ECM Engine Data: Engine Data Table0
    13:01.185: Com timeout: Expecting frame header byte
    13:01.408: Com timeout: Expecting frame header byte
    13:01.632: Com timeout: Expecting frame header byte
    13:01.637: Stop macro: ECM Engine Data: Engine Data Table0
    Thanx for the quick replies,
    Jason
    Turn on the menu option: View->Serial IO.
    Then log the same data as you have shown above.
    That will show more detail for us to work with.
    Although from what I have seen so far it looks like a faulty cable or connection somewhere. What cable are you using?
    Oct 2007
    I purchased the cable over Ebay, these links are some pics http://i20.ebayimg.com/03/i/000/a2/46/d976_1.JPG
    http://i11.ebayimg.com/03/i/000/a2/48/00a7_12.JPG
    The extra info is as follows:
    VT File,
    54:33.591: Opening COM2 8228,8,N,1
    55:01.830: Check vehicle interface...
    55:01.837: Waiting for Aldl bus silence of at least 10ms...
    55:01.845: Requesting Max232 interface to acknowlege: $FF,$55,$AC...
    55:01.845: Start writing frame
    55:01.845: Send: $FF,$55,$AC
    55:01.846: Finished writing frame
    55:01.846: Wait 10 ms after writing, before reading...
    55:01.856: Start reading frame
    55:01.856: Aldl frame header byte: $FF
    55:01.856: Aldl frame length byte: $ 0
    55:01.856: Recv: $FF,$55,$AC
    55:01.856: Finished reading frame
    55:01.856: Max232 interface detected OK
    55:01.857: Scanning for heartbeat and chatter frames...
    55:01.857: Waiting for Aldl bus silence of at least 10ms...
    55:01.865: Start reading frame
    55:01.965: Com timeout: Expecting frame header byte
    55:02.014: No chatter found
    55:05.779: Start macro: Engine data and DTCs: DATADTC
    55:05.790: Synchronising ALDL communications...
    55:05.790: Waiting for heartbeat: $08,$55,$A3
    55:05.790: Waiting for Aldl bus silence of at least 10ms...
    55:05.797: Start reading frame
    55:05.897: Com timeout: Expecting frame header byte
    55:05.921: No heartbeat found - ALDL not synchronised yet
    55:05.926: Synchronising ALDL communications...
    55:05.926: Waiting for heartbeat: $08,$55,$A3
    55:05.926: Waiting for Aldl bus silence of at least 10ms...
    55:05.927: Start reading frame
    55:06.028: Com timeout: Expecting frame header byte
    55:06.052: No heartbeat found - ALDL not synchronised yet
    55:06.057: Synchronising ALDL communications...
    55:06.057: Waiting for heartbeat: $08,$55,$A3
    55:06.057: Waiting for Aldl bus silence of at least 10ms...
    55:06.058: Start reading frame
    55:06.158: Com timeout: Expecting frame header byte
    55:06.182: No heartbeat found - ALDL not synchronised yet
    55:06.191: Stop macro: Engine data and DTCs: DATADTC
    VS File,
    53:35.277: Check vehicle interface...
    53:35.286: Waiting for Aldl bus silence of at least 10ms...
    53:35.286: Requesting Max232 interface to acknowlege: $FF,$55,$AC...
    53:35.286: Start writing frame
    53:35.286: Send: $FF,$55,$AC
    53:35.287: Finished writing frame
    53:35.287: Wait 10 ms after writing, before reading...
    53:35.297: Start reading frame
    53:35.297: Aldl frame header byte: $FF
    53:35.297: Aldl frame length byte: $ 0
    53:35.297: Recv: $FF,$55,$AC
    53:35.297: Finished reading frame
    53:35.297: Max232 interface detected OK
    53:35.298: Scanning for heartbeat and chatter frames...
    53:35.298: Waiting for Aldl bus silence of at least 10ms...
    53:35.306: Start reading frame
    53:35.507: Com timeout: Expecting frame header byte
    53:35.587: No chatter found
    54:19.292: Start macro: ECM Engine Data: Engine Data Table0
    54:19.293: Start writing frame
    54:19.293: Send: $F4,$57,$01,$00,$B4
    54:19.294: Finished writing frame
    54:19.294: Wait 10 ms after writing, before reading...
    54:19.304: Start reading frame
    54:19.304: Aldl frame header byte: $F4
    54:19.304: Aldl frame length byte: $57
    54:19.304: Recv: $F4,$57,$01,$00,$B4
    54:19.304: Finished reading frame
    54:19.304: MAX232 echo: $F4,$57,$01,$00,$B4
    54:19.304: Wait 10 ms after writing, before reading...
    54:19.314: Start reading frame
    54:19.514: Com timeout: Expecting frame header byte
    54:19.552: Aborting request due to previous error
    54:19.556: Start writing frame
    54:19.556: Send: $F4,$57,$01,$00,$B4
    54:19.557: Finished writing frame
    54:19.557: Wait 10 ms after writing, before reading...
    54:19.567: Start reading frame
    54:19.567: Aldl frame header byte: $F4
    54:19.567: Aldl frame length byte: $57
    54:19.567: Recv: $F4,$57,$01,$00,$B4
    54:19.567: Finished reading frame
    54:19.567: MAX232 echo: $F4,$57,$01,$00,$B4
    54:19.567: Wait 10 ms after writing, before reading...
    54:19.577: Start reading frame
    54:19.775: Com timeout: Expecting frame header byte
    54:19.812: Aborting request due to previous error
    54:19.815: Start writing frame
    54:19.815: Send: $F4,$57,$01,$00,$B4
    54:19.816: Finished writing frame
    54:19.816: Wait 10 ms after writing, before reading...
    54:19.826: Start reading frame
    54:19.826: Aldl frame header byte: $F4
    54:19.826: Aldl frame length byte: $57
    54:19.826: Recv: $F4,$57,$01,$00,$B4
    54:19.826: Finished reading frame
    54:19.826: MAX232 echo: $F4,$57,$01,$00,$B4
    54:19.826: Wait 10 ms after writing, before reading...
    54:19.836: Start reading frame
    54:20.035: Com timeout: Expecting frame header byte
    54:20.090: Aborting request due to previous error
    54:20.099: Stop macro: ECM Engine Data: Engine Data Table0
    Thanx for the time and effort,
    Jason
    There are 3 possible reasons (that I can thing of right now) that may cause what you are seeing.
    1. The vehicle's PCM is not transmitting any data in response to the request: $F4,$57,$01,$00,$B4, or there is a fault in the OBDII connector/loom wiring.
    You would need to borrow a Tech1 or other scan tool capable of communicating with the VS to check that the ALDL comms is functional.
    i.e. take it to a Holden dealer and see if their Tech1 can communicate with it.
    2. The EFILive software is not communicating with the ALDL cable, but is instead talking to the laptop's built in modem.
    Check the COM port assignment of the virtual serial port that is configured for your ALDL cable. Did you uinstall the USB drivers for the USB/ALDL cable and configure the virtual COM port? Make sure EFILive is using the same com port.
    If EFILive is connecting to the COM port assigned to the modem (instead of the ALDL cable) it may receive data back from the modem so that it "thinks" it is connected to the ALDL cable.
    3. The interface cable is faulty.
    I'm not sure how to test for that possibility, you'd need to ask the seller or manufacturer.
    Oct 2007
    Red face
    Thanks paul, will give it a try and run down a local holden dealer.
    Again thanx for the time.
    regards
    jason
  1. Aussie VX V6 Series 2 commodore
    By marcu5 in forum EFILive V4
    Last Post: July 22nd, 2009, 08:50 PM
  2. VY Series 2 V8
    By WestieVYCalais in forum EFILive V4
    Last Post: February 16th, 2009, 07:50 AM
  3. 3800 series II
    By DURAtotheMAX in forum General (Petrol, Gas, Ethanol)
    Last Post: October 18th, 2007, 05:06 PM
  4. GMT 800 Series Light Duty Trucks
    By Steve Bryant in forum General (Petrol, Gas, Ethanol)
    Last Post: March 8th, 2004, 02:09 AM
