I did several logs.
Log_0018 - This los shows very lean conditions right after small throttle movements.
Log_0019 - This log shows a very lean startup around 20:1, and slowly ramping down to ~14.5:1 AFR.
Log_0020 - This log shows very lean conditions right after small throttle movements. This was an autoVE log, and at idle, it looked like I was in the 70 kPa cell at 800 rpm. I had a lot of data there, and the BEN was 1.06.
I applied the BEN, but since it was only one cell, I did it by hand. I multiplied the 400 and 800 rpm rows by 1.07. I multiplied the 1200 rpm row 1.04.
Log_0021. This log is an autoVE log as well. I wanted to see how my VE corrections did. From the new BEN, it looks like my corrections had absolutely no effect on the newly calculated BEN. Is the VE talbe even used at idle? Why would my corrections make no differnce in logs done within 10 minutes of each other?
Here is my current tune. Not much done to it. The car is not drivable, so I can't do any autoVE tuning. Right now I am really just grasping for any help I can get. I've tried many different things. Finally it looks like my warm idle is at ~50-60 steps.
I'll attach the logs and my tunes in a minute, when I figure out how.
