Results 1 to 3 of 3
Thread: IFR - FlashScan vs LS1 Edit
    Sep 2003
    Default IFR - FlashScan vs LS1 Edit
    I have noticed that when looking at the IFR in FlashScan the table indicates that the injectors flow more near atmosphere and less @ 20Kpa. When I look at the same vehicle in LS1Edit the table makes sense where the injector would flow more at a greater pressure drop, ie; 20Kpa.
    Can someone enlighten me as to what I am seeing here?
    Scott Brown
    Jul 2004
    I believe the pressure displayed on the EFI Live chart is manifold vacuum and if that's the case then the chart makes sense as the higher the number the more pressure across the injector.
    Ira
    Ira is right: the pressure scale is vacuum (VAC = BARO - MAP).
  1. V6 commodore edit
    By nathans1987 in forum General
    Last Post: June 8th, 2010, 04:46 PM
  2. Can't edit COS
    By sinr98 in forum Custom Operating Systems
    Last Post: June 4th, 2010, 10:21 AM
  3. Edit map properties
    By driver456 in forum General
    Last Post: January 7th, 2010, 01:50 AM
  4. tunning from flashscan to edit
    By ace68 in forum General (Petrol, Gas, Ethanol)
    Last Post: January 23rd, 2006, 05:16 PM
  5. Flashscan compatable with an Edit file?
    By Nick 02 Z06 in forum General (Petrol, Gas, Ethanol)
    Last Post: February 13th, 2005, 12:39 PM
