Can and how can I put one tune with a vin to another vehicle with the same os? Do I just change the vin?
Use one tune for more than one vehicle.
You can put a tun in as many vehicles that you want, there is no limit. Of course you will need to have a license for each different PCM you load it into. Be observant, most vehicles have different builds that would not readily accept a generic tune. Different years, gears, engine sizes and transmissions to start with all require specific builds. Note the segment numbers and see how many different combinations for a certain operating system exist.
Al
Same OS? Just flash it. The VIN isn't written to the PCM as part of a normal flash.
2009 Z06 LS7 / 2008 Sierra Denali AWD L92 6L80E
Flashing control modules since 2001. 8-)
Who needs a MAP sensor on a supercharged LS6 anyway.
