I've been down for a while, but i'm startin to put the car back together to get back in the game. I'm in the process of cleaning up my wiring harness. I'm gettin rid of everything that is not necessary. I have no power options in the car, so the only thing the bcm has an effect on is the vats. Where in the efilive software do I turn vats off, and will that completely shut off the vats as to where I can take the bcm out and cut out all the wires for it, or is there more to it? Thanks for any help guys, I asked and searched on here and ls1tech and haven't seen conclusive info, seen mixed answers, some say you can take it out and turning it off in the pcm works, others say certain wires from the bcm need to be spliced together. So i'm hopin I can get a straight answer so I can figure out what to do with the bcm wires.
