Results 1 to 2 of 2
Thread: A4 downshift double surge???
    Jun 2005
    Default A4 downshift double surge???
    Has anyone ever experienced this? When I'm cruising along at 65~70mph and floor it, the trans jumps into 2nd for the last few rpms of that gear. It kicks/jumps like any other downshift. But, after about .5 seconds it kicks again like it disengages and re-engages the drivetrain briefly. One of my logs shows the downshift where the VSS is at 68mph and the initial kick is pushing the car to 72mph. Then the car accelerates to 75mph just before it feels like something disengages. The VSS drops to 73mph during this second kick. When it feels like power is fully restored to the drivetrain (like the original downshift kick), the car takes off for the remainder of 2nd gear. It's hard to tell if this is spark related, torque management/abuse mode related, TCC related, etc. Are there any parameters/tables that would cause this either in the engine or trans settings? I would like to get a grip on this before I start tweaking the trans settings too much.
    Post a log chart showing:
    VSS
    RPM
    SPARK
    TP
    MAF
    MAP
    IAT
    ECT
    TFT
    PRND
    Current Gear
    PCS
    last shift time
    last shift error
    TCC PWM
    and also these pids or state pids (I can't look them up right now...):
    TCC flags
    brake pedal switch flag
    3-2 solenoid
    Be sure to be logging in 10 fps mode.
  1. Decel Downshift
    By L31Sleeper in forum CAX Files
    Last Post: February 21st, 2010, 02:45 PM
  2. Brake downshift
    By L31Sleeper in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: February 18th, 2010, 05:31 PM
  3. V2 buttons double clicking?
    By kbracing96 in forum FlashScan V2 BB Logging
    Last Post: December 29th, 2009, 03:21 PM
  4. Billet LT1 Timing Cover - Clears Double Row Timing Chain
    By S10Wildside in forum Conversions / Aftermarket Parts
    Last Post: November 17th, 2009, 01:15 AM
  5. Max KR on 4th-2nd Downshift
    By Denaliano in forum Gen III V8 Specific
    Last Post: March 16th, 2008, 12:23 PM
