hi guys very new to this i am just about to order a flash scan i have a slipping auto 4l60e 2nd only can i use it to increase the line preasure to stop the slipping as a temp fix?
cheers
cheers
The tunetool allows you to increase the shift pressure... i.e. the line pressure during a shift, and not while in a particular gear;
so, sorry, the short answer is no.
I know its not the right way to do it, and probably shouldn't, BUT, couldn't you play with {D3801} Force Motor Current table to "trick" the PCM into higher apply pressures?Originally Posted by joecar
It will affect hold pressures in all gears plus you would have to adjust the shift pressures down to avoid harsh shifts.
This weekend, I was working on a car that had come from a transmission mechanic, he wanted me to increase hold pressures under acceleration. I couldn't do it because those tables are not available to us.
Dave.
Oh, yes, good thinking Dave , could do that, didn't occur to me because I'm so used to not touching that table...
Thanks for the help guys
"I know its not the right way to do it, and probably shouldn't, BUT, couldn't you play with {D3801} Force Motor Current table to "trick" the PCM into higher apply pressures?"
There was a lot of discussion about this in the past. The conclussions reached from pressure testing was that max line pressure could not be increased electronically, it only increased part throttle pressure and not WOT. I'd be interested to know if your changes help with the slipping problem.
2003 red vert
Mods:
LPE 100mm MAF
RPM Level 6/4L60e trans
3.42 gears
Yank SS3600
1-7/8" AR headers
Z06 exhaust
470rwhp 437rwtq
So is there no way to adjust pressure @ wot?
http://www.ls1tech.com/forums/showthread.php?t=114376Originally Posted by Afterhours Performance
Try here.
2003 red vert
Mods:
LPE 100mm MAF
3.42 gears
Yank SS3600
1-7/8" AR headers
Z06 exhaust
470rwhp 437rwtq
Thank you that is a really great thread!!
