2007 H2 with recently installed magnusson, I can't get PE mode to add fuel (AKA lean @ WOT) normal and hot PE mode enable set to 65%, PE time delay set to 0, PE RPM set to 1200, ??? what am I missing...
Post up your tune if you can.
not sure how to attach it...
ok- i have tweaked a little since this tune, but all PE values are the same, ithink
gonzanbachtune2.tun
