Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Newbie - Calling all 07 TBSS Tuners
  1. #11
    Im not telling you what to do, Im just forwarding my knowledge of the TB SS and its extremely pansy transmission that cannot handle the LS2 and the weight of the TB. If you think you can 0 the times and everything, go for it but if you do anything more than just a CAI and exhaust, maybe efans, you should probably get a built trans to hold the power.
  2. #12
    Senior Member TLKSCHP's Avatar
    Dec 2005
    I have also been playing with the tune in my TBSS. As for zeroing out the tables that apears to be what the superchips hand held does. i didn't run mine with it at zero but I have 2 friends that have been doing it several months now since they use the hand helds. Both my friends and mine don't like the shift points messed with on the 2-3 shift, it won't shift and just hangs their like a speed limiter.
  3. #13
    Oct 2006
    Not to butt in , but zeroing the shift times just removes the "Adaptive Shift Learning" correct ?
    And TM just pulls timing or throttle at shift correct ?
    Just curious !
    2006 Trailblazer
  4. #14
    Oct 2007
    There are a few things I think I can add to this post. I didn't read everything so dont flame me if I missed something.
    I have tuned 20 06 TBSS's and 9 07 TBSS's with HPT.
    If you have a stock trans in a TBSS removing all the torque management will toast the trans with very minimal mods. I personally took out 4 transmissions in my 06 TBSS with varying levels of mods from bolt on's to a 637rwhp turbo.
    Second, if you 0 the trans tm tables completely in an 07 you may get the notorious "dead petal" leaving at least a 1 in the TM abuse tables will keep the check from looping and instigating the dead pedal issue.
    Third,
    If you are going to kill torque management on a stock trans...leave the downshift torque management. It will save your trans and keep it together a lot longer than one without it.
    Lastly,
    I would suggest that if you have a mod happy TBSS customer advise them to build the trans and put a converter in it with a trans cooler. At a minimum do servos and a trans cooler. Everything they do after building the trans will be better served by having the built trans and a converter. The TBSS is a big heavy truck, it is hard on the trans and hard to get out of the hole. I have an 06 and an 07 both make 600ish wheel horsepower and I speak from LOTS of experience.
  5. #15
    Yep, cooler and servos before you really start doing anything more than a tune.
  1. Replies: 4
    Last Post: April 27th, 2008, 05:03 PM
  2. Calling all beta testers.
    By Blacky in forum FlashScan V2 BB Logging
    Last Post: December 27th, 2007, 04:33 PM
  3. Calling EFILive Professional Tuners
    By Blacky in forum Lounge
    Last Post: April 20th, 2007, 03:22 PM
  4. Calling All 60 lbs injector users
    By 1bar in forum General (Petrol, Gas, Ethanol)
    Last Post: January 27th, 2007, 05:24 PM
  5. Strange Problem - Calling all experts
    By jamesbond2509 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: July 14th, 2006, 01:27 AM
