Results 1 to 8 of 8
Thread: Semi-Open Loop: what's the fuel economy like?
    Dec 2004
    Default Semi-Open Loop: what's the fuel economy like?
    I run Closed Loop (and PE enabled) and very happy with my fuel economy and power. I usually average 12-13L/100kms (18-20mpg). I've run full Open Loop before and quite happy with the engine's smoothness although fuel economy dropped to around 14L (17mpg) at best.
    For those running Semi-Open Loop what fuel economy figures are you averaging?
    Lifetime Member macca_779's Avatar
    Jan 2007
    Highway I'm getting low 8's Overall average of city/highway with avg speed of 62km/hr I'm receiving 12.2L/100km. Commanding AFR using B3647 1200-2000 below 55ka of high 15's to low 16's:1
    Dec 2004
    Thanks macca. Good figures for hwy.
    15-16:1 seems a bit lean for my car's need. It likes to run richer b/w 1200-2000rpm, low MAP.
    Jan 2007
    Quote Originally Posted by SSbaby
    The timing I'm running helps. For example @.40/1600 I command 30deg, for the same RPM ramp it up to 40deg @.08 Works well
    Dec 2004
    Yes. Good timing helps fuel economy. I run slightly higher timing @ .40 but less @ 0.08 across 1600rpm.
    Dec 2004
    Bump. No more responses?
    If the number of responses is any guide, I can only assume that 14.63 stoich is not commanded much across most VE tables... It implies to me that semi-open loop (OS3) is not really worth running as it doesn't give any additional benefit over closed loop or open loop?
    (Semi-open loop does give you an indirect sanity check that your wideband was working right.)
    Dec 2004
    Thanks Joe.
    I guess if the O2s get dodgey... I won't be replacing them with new ones. I'll just flash in OS3 and go Open Loop.
  1. cos3 no semi open loop
    By 64camino in forum Gen III V8 Specific
    Last Post: February 5th, 2010, 01:37 PM
  2. 02020003 with 0411 will not go semi-open loop
    By LS1_Dragster in forum Custom Operating Systems
    Last Post: August 14th, 2009, 12:33 AM
  3. Setting up for semi open loop
    By jfclubby in forum Custom Operating Systems
    Last Post: September 19th, 2008, 01:56 AM
  4. COS5 semi open loop ?
    By RandyWS6 in forum Gen III V8 Specific
    Last Post: April 10th, 2008, 02:38 PM
  5. Open Loop Fuel Economy Results
    By oztracktuning in forum Custom Operating Systems
    Last Post: March 12th, 2006, 10:38 PM
