I've been logging for various conditions, and the "standard" sample rate has been sufficient. Currently I'm tuning for the 1/4 mile, and the sample rate is less than satisfactory. Is there anyway to adjust that?
Also a few other questions I had for the EFI Live crew:
Will there be an update allowing more than 1 controller to be recorded during the same log, mainly ECM and TCM?
What's the status or time frame on the black box logging feature? that was the reason I purchased your product, and am still patiently waiting.
Is there any chance that you could add more external sensor expansion ports, as I would like to run more analog sensors than there are ports available. I know that's a lot to ask, and probably a far way off.
I would also like to say that I do like your product, I find it mostly intuitive and easy to use. I've had great success with it and am getting alot of questions at the track, especially as my ET's keep dropping. Thanks for all your hard work it really shows in your product.
