Results 1 to 5 of 5
Thread: Sanity Check on Commanded AFR
    Lifetime Member Kevin Doe's Avatar
    Aug 2007
    Default Sanity Check on Commanded AFR
    Could someone look at my log and tell me if you think the commanded AFR makes sense. I'm setup for AutoVE right now, so I should be in OLSD mode.
    I didn't expect the commanded AFR to be 14.68:1 with all the changes made in the autoVE tutorial, mainly the changes to the 3 or 4 rows in the open loop commanded EQ ratio table. Anyone care to take a quick look.
    Most of the log is a highway cruise in 6th.
    Thanks,
    Kevin
    Jan 2007
    Just looks like the BENs are rich all over. But for the high load cells they aren't rich even though the BENs say they are. It should commanded richer AFR at high load so the BENs are misleading.
    Post your commanded AFR in open loop table. It should of commanded 12.6 or so. Not 13 in the high load.
    Only thing that makes me wonder is it shows you hit 30% tps max and it shows you hit 93 kPa. Seems like it should take more pedal pressure to have such low vacumn. Maybe you have a large cam though.
    Aug 2007
    You are correct, I have a very large cam, MS4.
    Aug 2007
    Can anyone look at this log and see if the commanded AFRs are what you would expect for a car setup in OLSD by following the procedure in the AutoVE tutorial.
    I would be much appreciative.
    For light throttle and the MAP range shown in the log, commanded AFR is probably ok, but it's hard to tell without more throttle range (log doesn't show enough load).
    The idle (near the beginning of the log) shows a high MAP, you have an air leak of some kind.
  1. CALC.PID for simultaneous MAF & VE Calibration - need sanity check
    Last Post: January 7th, 2015, 01:33 PM
  2. Sanity check please
    By Forcefedperformance in forum Gen III V8 Specific
    Last Post: June 9th, 2010, 12:52 PM
  3. ls1 with ls7 maf, sanity check, input appreciated
    By rosey in forum Gen III V8 Specific
    Last Post: November 1st, 2009, 02:51 PM
  4. sanity check of semil-OL OEM tune
    By stigmundfreud in forum Gen III V8 Specific
    Last Post: October 5th, 2008, 12:05 PM
  5. Sanity check, please?
    By critter in forum General (Petrol, Gas, Ethanol)
    Last Post: September 19th, 2007, 02:14 PM
