This was an internal issue with the OS if I remember correctly as we tuned the car. I would contact Paul or Ross to see.
Send it to support@efilive.com
Howard
Gonz
Thinking back... it was corrected by EFIlive.
Blacky created a new calibration, I loaded it or something and it went away.
It was a false DTC
Check with him.
Bob
Thanks BOB,this issue started about the same time I updated the firmware the other day.I also have been getting codes c0035 c0044 wheel speed codes,now thoses have been coming on for sometime,those I thought could have been tied to when the truck had a front wheel bearing replace under warrenty.I had noticed it after that time.Althought everything works fine.
EFILive Developer
Site Admin
I'm sure that problem is fixed in the latest 7.5.3 release along with the FlashScan V2.4.70 firmware. Are you running those software versions?
P.S. Please note the standalone DTC display in FlashScan still has the B and C codes swapped around as per this thread.
http://forum.efilive.com/showthread.php?t=7338
That will be fixed in the next firmware update.
Yes I have 7.53 , I had to update both firm and USBs after loading 7.53 I reflashed it today and now I am getting
(4) P2A0l 02sensor codes
and c0040 and c0035
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
