Results 1 to 10 of 14
Thread: Fixin to start DPF Delete
    Oct 2007
    Default Fixin to start DPF Delete
    I am fixin to start a LMM DPF delet can you tell me which codes to start with and do I need to go ahead and change the exhaust or can I wait a few days
    Oct 2007
    You do know why the DPF is there, right?
    Ryan
    1970 El Camino *Stolen*
    2004 GTO M6
    Lifetime Member Cougar281's Avatar
    Jan 2006
    Quote Originally Posted by ElusiveR
    Ryan
    To clog up, cause problems and burn extra fuel, costing more to run it and put more money in the oil companies pockets.....
    I honestly can't see how burning more fuel and pumping more CO, CO2 and NOx into the air is better than letting what little soot these trucks actually make with stock tunes go to atmosphere...
    Oct 2007
    Quote Originally Posted by Cougar281
    :roll:
    You think they let out more emissions? Please, tell me more....
    2004 GTO M6
    Oct 2007
    Any way did the DPF delete and the thing runs like a striped ape and blows good smoke
    Jan 2006
    :roll:
    I honestly can't see how burning more fuel can possibly NOT put out more gasses...
    And lets not forget the emissions produced by the refineries to make the extra fuel being burned.
    Oct 2007
    Quote Originally Posted by dustinparsons
    Congrats on making the world a better place for future generations....
    I'm at work now, so I don't have much time, but I'll see what I can find for you. You're right that there is a higher volume of gas, but it's cleaner.
    You're talking about 3-4% more fuel at the high end of additional consumption - well within refinery capacity that already exists. Besides, diesel takes less refining than gasoline, so if DPF's make diesels clean enough to make them a good idea for more people and also reduces oil consumption (from higher mileage), wouldn't it help to make a greater amount of diesel than gasoline?
    Ryan
    2004 GTO M6
    Jan 2006
    Ryan
    3-4% on the high end? How about those who went from low to mid teens to high teens/low 20's by only removing the DPF? 4% is less than 1mpg. The High end is more like 25% or more. The only thing the DPF "cleans up" is soot. The cats on diesels don't work the same way they do on gassers. With a modified tune, yes, our diesels can pour out copious amounts of soot, but on stock tunes, they produce very little soot. I know with my truck, WOT from dead stop will put out no visible soot.
    Bottom line, you believe what you believe, I believe what I believe. We'll do what we want with our trucks and agree to disagree. Sound fair?
    Nov 2007
    Default Bio
    I'll chime in, so I can run something greater than B5. I'm not an expert but from what I read I am assuming that the DPF limits the percentage of Biodiesel you can run due to filter clogging. I would live for someone who knows more about it to elaborate. I figure using biodiesel will counteract the emissions output from removing the filter.
    Oct 2007
    Have you ran any bio through your LMM, I have'nt tried to run any through mine since the DPF delete but have no problems at all since I turned the regen feature off for the DPF. For anybody going to tune a LMM there are some CAL files that you need to see the DPF section of the LMM engine operations if you need these email me and I will gladly send them to you. I would put them on here but don't know how and my web page is lacking.
    dusty@dustysdieselstuff.com
  1. dpf delete help
    By escalante127 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 6th, 2010, 08:27 PM
  2. Cold start perfect, Warm start flares high
    By samh_08 in forum Gen III V8 Specific
    Last Post: May 12th, 2009, 09:36 PM
  3. Cold start great but warm start sucks."Idle
    By mvvette97 in forum Gen III V8 Specific
    Last Post: October 26th, 2008, 12:22 AM
  4. 7.5 LMM DPF delete and EFI V2
    By clickjocky in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: February 5th, 2008, 03:36 PM
  5. Cat delete
    By Automotive Innovations in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: December 27th, 2007, 11:52 PM
