Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Truck wont shift and getting a U0100
    Junior Member heathgu's Avatar
    Feb 2007
    Yeah cougar,
    thanks for the advise again. I will see what i can find. The truck has gone to my mates who is a auto sparky. See what he come up with this afternoon.
    Cheers and thanks heap Heath.
    LBZ/ALLISON going into a NISSAN GU PATROL UTE some how???
    Sunshine Coast, Queensland.
    Feb 2007
    Hey cougar,
    I have check everthing twice and i am pulling my hair out.
    Could it be something like the tcm and the ecm are not from the same vehicle. Would this cause the break down in communications??
    I have no more ideas.
    Cheers Heath
    Shouldn't, unless they changed something for the newer controllers. I had a TCM from a 2003 8100 in my truck at one time and it worked normally, except for the weird shifts. No codes, though. Did you change the VIN(s) so they all match?
    E-mail me a list of the codes if you can.
    Dec 2007
    I have a similiar problem on a 2006 sets P0700 and U0100. reset the codes and its fine for about two weeks. Checked power and grounds at the TCM found the Transmission connector at the back of the tranny not seated it would move back and forth a little contact cleaner on all connections. The code won't clear it self from what i read so you would have to clear it manually. Mine comes on right after start. is yours similiar? Does it put tranny into limp mode?
    2006 Silverado LBZ Stock.
    Quote Originally Posted by petestoy
    Heath's problem was a bad TCM. He also had a LOT more codes than P0700 (TCM Request MIL) and U0100 (Lost Comm With ECM/PCM A). Are those the only codes you get?
    Dec 2007
    That is what the dealer told me two weekes ago. the mil light came back on and its responding the same way. I ordered EFI Live on Wednesday and have not recieved it yet to verify.
  1. help truck wont start!
    By chev in forum General (Diesel)
    Last Post: March 29th, 2010, 02:39 PM
  2. 'Race truck' wont start..
    By nonnieselman in forum Gen III V8 Specific
    Last Post: January 12th, 2010, 08:33 AM
  3. sterio swap and truck wont start
    By pullincrazy88 in forum General (Diesel)
    Last Post: September 2nd, 2009, 02:42 AM
  4. help truck wont crank?
    By dpduramax in forum Duramax LB7
    Last Post: May 12th, 2009, 06:06 AM
  5. wont shift to 5th under WOT
    By pullincrazy88 in forum Allison 5 & 6 Speed
    Last Post: April 29th, 2009, 09:09 AM
