Results 1 to 10 of 10
Thread: need help with SPEEDO CALCULATOR
    Lifetime Member Boost's Avatar
    Dec 2006
    Default need help with SPEEDO CALCULATOR
    Hey guys,
    Lately I have been having trouble with my speedo calculator. I have the latest version of everything, and when I click on the speedo caclulator and type in the tire size, it doesn't automatically jump to the adjust %. It used to do that before. Even if I click on the tab for the shift point correction the adjust % is 0. Has anyone encountered this or do I have to do it differently?
    Please help, speedo adjust is big business on the Duramax since it can't be done by the Tech 2. Thanks a lot.
    8.7 @ 84 (1/8 mile) bolt-ons
    Dec 2006
    And yes I do hit APPLY.
    The shift point correction is a manual task now. You need to enter the original and new diff and tire sizes. The speedo calculator will then calculate the shift point adjustment percentage.
    Obviously that process assumes that the shift points were correct with the original settings.
    Lifetime Member Ninety8C5's Avatar
    Sep 2003
    I input old & new tire size and diff and the 'Adjust by:' stays at 0.00. Is there somthing else that needs to be selected/clicked on or should the 'Adjust by:' change as you input info?
    I just tried several other years and it looks like it doesn't work on 1997/1998 tunes. On other years the original tire size and diff are filled in. On 97/98 cars no original data, but even putting in old & new data doesn't cause 'Adjust by:' to change.
    Dec 2006
    Thumbs up
    Thanks for the input Blacky. Will try that and give feedback.
    Quote Originally Posted by Ninety8C5
    The adjust by should change each time you change the values in tire size and/or diff ratio.
    While testing it I noticed that entering a new tire size in inches calculates the wrong tire size in mm. So fo accurate results (until we get the next release out) you will need to enter the new tire size in mm.
    See before and after screen shots.
ID:	2246   Click image for larger version.
    Sep 2003
    I've attached a screen shot of the Shift Adjuster when I tried it on a 98 Vette. I've also tried a 98 Camaro with the same results. The 'Adjust by:' stays at 0.0 even if I change the diff. ratio.
Name:	Shift Adjust.jpg
    Sep 2003
    I just tried 7.4.2 build 659 and the Shift Adjuster works. So I guess it was broke in 7.5 build 21.
    You must specify non zero values for all entries.
    Sep 2003
    That worked. It was the zero entries that was messing it up.
    Thanks!
  1. Speedo-Calculator ?
    By GAMEOVER in forum General (Petrol, Gas, Ethanol)
    Last Post: April 3rd, 2014, 10:32 AM
  2. problems with the speedo calculator
    By goldbergv95 in forum LL8 4.2L In-Line 6 - P10 PCM
    Last Post: December 19th, 2008, 10:34 AM
  3. LMM Speedo Calculator
    By Redline Motorsports in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: April 28th, 2008, 06:51 AM
  4. Speedo Calculator issues...Help Please
    By KAZ MotorSports in forum FlashScan V2
    Last Post: June 11th, 2007, 05:44 PM
