Results 1 to 10 of 10
Thread: Problems after programming
    Jul 2003
    Default Problems after programming
    I programmed an 08 z06 ls7 that is to go to an autoshow and the dealer wanted to restrict the rpms and speed limit.
    After reflashing, when you open the doors, windows roll a bit down, but don't come back up when the door is closed... anyone know why is this happening and how can it be fixed?
    Lifetime Member eboggs_jkvl's Avatar
    Apr 2004
    Did you disconnect the battery? SOunds like the windows need to be reindexed. Even if you didn't cut the battery, reindex the windows.
    Elmer
    Jul 2003
    How do you do the reindexing??? I did disconnect the battery.
    Thank you
    Apr 2004
    Ok, start the car.
    Lower the window all the way. Raise the window to the top and hold button up for 3 seconds and release the button. Immediately lift the button again and hold for another 3 seconds. Repeat for the other window.
    Jul 2003
    THANK YOU
    that did the trick
    it appears battery was low and since programming turns on the headlights, well... there you have it, vcm reset itself..
    Thank you!
    Quote Originally Posted by Highlander
    What?
    Apr 2004
    Quote Originally Posted by GMPX
    What?
    If the emergency brake is down, turning on the acc will bring on the headlights if in a garage. I think that's what he means.
    2014 Corvette Convertible, Torch Red, A6, Z51, 3LT, NPP Exhaust
    Jul 2003
    No, not what i mean.. everytime i get a vehicle in programming mode it turns on the headlights.
    Apr 2004
    Goodness.... My Camaro (98 ) does not switch on the lights nor does my Corvette (07) as long as I have the emergency brake set. I've tuned both and in the garage without any headlights coming on.
    Your lights come on? Weird!
    My 02 TrailBlazer (LL8 P10 PCM) doesnt do that either...
  1. Programming the DIC
    By Whippled 496 in forum Tips and tricks
    Last Post: December 14th, 2012, 04:44 PM
  2. programming LC-1
    By z06ufgrad2002 in forum General (Petrol, Gas, Ethanol)
    Last Post: October 18th, 2009, 10:22 AM
  3. Need Help Re-Programming The BCM
    By cwksf in forum General
    Last Post: July 26th, 2009, 03:05 PM
  4. T42 Programming Problems
    By arubenstein in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: March 22nd, 2008, 06:55 PM
