Results 1 to 6 of 6
Thread: Anyone have A0014 table working correctly with F.I.???
    Jun 2005
    Default Anyone have A0014 table working correctly with F.I.???
    I run a Twin turbo motor and have my AFR dialed in at 70 degrees F.
    I am concerned that with my IAT swings of 60 degrees to 140 degrees at full boost that I may need a different then "standard" IAT correction?? I have not investigated this too much yet, the car has been on jackstands for 3 months!
    Any turbo or supercharger guys use this succesfully yet? ahould it matter if it F.I. or N/A???
    '71 chevelle
    Twin turbo ls1
    1000 HP 93 octane street car!
    96 lb injectors
    Jun 2005
    Anybody??
    There are not to many "recent" posts on this. Definetly nothing on an a turbo car.
    '71 chevelle
    Twin turbo ls1
    96 lb injectors
    Oct 2004
    What is your normal (regular) average intake temp? This is the point where the multiplier will be 1.00.
    I can send you calculated values I have (and use in my non FI car). It would be interesting tee see what they are like compared to your logged values.
    Andrew
    EFILive Crew
    Jun 2005
    I will check a log tomorrow, my car has been down for 3 months waiting on new wheels, so I figure it is a good time to start finalizing my tune once and for all. If I remember they are usually in the 75-80 degree F range. During a 1/4 mile run they aproach 140 degrees.
    '71 chevelle
    Twin turbo ls1
    96 lb injectors
    Aug 2005
    Yep, works fine for me, but having the magnacharger radix, my table won't work well for you. Metal intake manifold with IAT sensor mounted within...
    Sep 2005
    Here is what I run on my turbo truck, but I have an intercooler and meth, so my IAT drop below ambient when the meth starts and only comes up to about 10* over ambient at 12lbs of boost in the 1/4. A/F stays right on.
    0.911377
    0.922607
    0.934082
    0.946289
    0.958984
    0.972168
    0.985596
    1.000000
    1.014892
    1.030517
    1.046875
    1.063965
    1.081787
    1.100830
    1.120849
    1.141846
    1.164307
    1.187988
    1.213135
  1. Replies: 11
    Last Post: July 10th, 2008, 11:44 AM
  2. IAT VE multiplier table A0014 Q's.....
    Last Post: April 7th, 2008, 01:56 AM
  3. B0729 table doesn't function correctly
    By lakingslayer in forum General (Diesel)
    Last Post: February 9th, 2008, 03:20 PM
  4. A0014
    By SSpdDmon in forum Custom Operating Systems
    Last Post: June 25th, 2007, 05:00 AM
  5. Conversion Calculator not working correctly
    By AustinL911A in forum General (Petrol, Gas, Ethanol)
    Last Post: February 1st, 2007, 02:42 AM
