Results 1 to 4 of 4
Thread: Boost VE map...............
    May 2006
    Default Boost VE map...............
    When using the COS3, and logging BEN factors, can I just modify the existing map to show 105-285 KPa or is there a separate map that I should make for when the car is going into boost?
    What pid's should I use if using a different map?
    Thanks in advance!
    Lifetime Member johnv's Avatar
    Jan 2005
    Quote Originally Posted by FreddyG
    Thanks in advance!
    Use A0009 Boost VE table in the "EFILive Custom Calibration" tab
    Download the tutorial it's all it there.
    John
    Aug 2005
    Thanks in advance!
    Yes, you may use the same map. When you're done logging, highlight the entire table and copy with labels (Shift+Ctrl+C). Then you can paste with labels into both tables.
    Justin
    May 2006
    Thank You Very Much Guys!
  1. What AFR in Boost?
    By zapp168 in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: July 24th, 2007, 01:03 AM
  2. Use MAF for off boost/2 Bar SD when in boost
    By Earl H in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: May 24th, 2007, 12:58 PM
  3. Boost and EGT's
    By minytrker in forum Duramax LB7
    Last Post: February 14th, 2007, 03:41 AM
  4. Can you log boost?
    By AustinL911A in forum General
    Last Post: January 5th, 2006, 07:55 AM
  5. What happens when you go into boost?
    Last Post: March 29th, 2005, 05:49 PM
