I have a buddys car that we just put in a 408 solid rooler motor with big compression.We have been having problems with the car trying to make horsepower.With his setup we should be around 600rwhp and were 80rwhp down from that.The car runs like shit and its been dyno tuned.The tuner even said there is somthing wrong with the car after two pulls.I hooked up my laptop to his car to do a balance test and when i did the cyl were all weak some so bad the bar bearly moved.I know when i do mine its alot longer and the rpms even view.What doe's the balance test really do?Im starting to think his timing chain is one tooth off.We have been threw all the basic and were starting to think the chain.A motor that should pull to 7500rpms only pulls to 6400.Is there any other test that we can do with efi before we pull the front end of the motor apart.Thanks for any input.
