Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: Dry Tuning Questions
    Lifetime Member Beer99C5's Avatar
    Jul 2006
    Default Dry Tuning Questions
    I am going to be expiermenting in Nov w/ COS 5 and the VE multiplier, and I was looking overall at other items of interest and was wondering about the following:
    I am tuning a 100 Dry Shot on a H/C car
    B0120 RPM Thresehold for Airflow Calc...Being its a dry shot and MAF Dependant, my Dry is coming on @ 2800. Seems to me I want MAF calculation (its what feeds the Dry Fuel) when the dry shot is enabled.
    MAF tuning...ok so we tune the MAF best we can, I got it to 1% prior to the H/C...now though with the Nitrous, (Flow a function of pressure...) and tuning the MAF under Nitrous conditions seems like a different animal because you have bottle pressure a factor...Any Suggestions on MAF tuning while spraying Nitrous, or just use the VE multiplier with target bottle pressures?
    B0109 Blend IAT w/ ECT...seems to me "No" is the better pic to try and take advantage of the cooling effect of the nitrous on the charge, "Yes" Blending will skew it??
    1999 C5 A-4 Convertible
    1 of 245 Nassua Blue 99 Vert's, Blackwing, LS6 Intake, 42 # Injectors, Two Stage Nitrous System- Dry and a Wet Plate, EFI Live Scan/Tune V2, 1999 PCM with 2002 COS 5 OS Custom Nitrous Panel.
    Maine USA
    Lifetime Member Kevin Doe's Avatar
    Aug 2007
    Any results here? I'm planning no doing a dry shot as well, except in speed density mode. If they ever come out with a COS5 for the 1MB PCMs (2004 GTO).
    Jul 2006
    I am doing a test/tune session on the dyno end of Dec I will write up my results. I plan on the dry @2800 RPM, the major problem is I want to use the safety's built into my Trick Performance Nitrous gauge and set them up for 10-12 AFR, anything out of that it will shut down the nitrous system. I had the pin to ground wired to a toggle, but now I am going to wire it to the Dry Arm so it cannot be forgotten. The trick is going to be getting the AFR into the safety range prior to 2800 else the nitrous will activate late.
    Maine USA
    Jun 2007
    Quote Originally Posted by Kevin Doe
    You lost me here, if your running speed density, then your not running a MAF, how are you gonna use a dry kit?
    WWW.EFIAlchemy.com
    Aug 2007
    YOU, lost me with that question. Why could I not run a dry kit in speed density?
    With COS5, I should be able to setup the EFILive to add fuel, and reduce timing when an external trigger is sensed. That trigger will be when the nitrous is triggered.
    I think what he meant was that dry N2O kits are placed pre-MAF so when the N2O goes through the MAF the PCM senses this change in temp and can adjust fueling.
    You are talking about setting EFILive up so that when you hit a switch the fueling is already set specifically for N2O, basically hitting a switch vs letting the MAF make the changes for you.
    Am I close guys? Hope I am!
    The MAF senses increased "flow" which causes the PCM to add fuel.
    Thats the simple answer I was aiming for, thanks for reading my mind!
    Now if I could only read my Mrs' mind...
    Jun 2007
    While i see how that could work for a dry kit, its generally used for wet kits (at least in my experience) becouse with wet kits there is no way to control fuel or timing,
    Dry kits fire the nitrous in front of the MAF, when the MAF see's the nitrous it senses it as extra air, so it adds fuel to compensate, so if your in speed density with the maf turned off, it would not work
    WWW.EFIAlchemy.com
  1. couple 09 G8 GT tuning questions
    By Blk02Ls1A4 in forum Gen IV V8 Specific
    Last Post: March 25th, 2010, 05:28 PM
  2. LTFT tuning questions
    By stevedarman in forum General (Petrol, Gas, Ethanol)
    Last Post: January 2nd, 2010, 08:54 PM
  3. PE tuning procedures/questions....
    By BlackGMC in forum Gen III V8 Specific
    Last Post: February 12th, 2008, 12:03 PM
  4. help on Maf Tuning few questions..
    By MSGHUFF in forum General (Petrol, Gas, Ethanol)
    Last Post: May 14th, 2006, 07:42 AM
  5. Tuning VE Questions??
    By BowlingSS in forum General (Petrol, Gas, Ethanol)
    Last Post: April 23rd, 2005, 07:47 AM
