Bummer, but get some sleep man! You can at least take the beta firmware to Vegas and show it off, right?
Cant wait for it when you get back!
Oh well ... wouldn't do me much good anymore for the next couple months anyway, only thing I will be doing the next 5 days with the car is clean it and rub it down with a layer of Zaino, so ...
Got some comments and a suggestion...
Ok timestamps, with the pc you have access to a clock, with the v2 Im guessing we dont. Therefore it would be good if while logging we could press and hold a number key to "stamp" the log with something so we know where to look later on. Maybe make keys 0-9 work like that for 10 "stamps".. just a suggestion
Pity us vpw guys couldnt play while you play sema. Go take loads of pics of the booth girls!
2014 VF SV LS3 Maloo.
That's a brilliant idea Ringram. We have an event marker feature on the F-18's I work on, simple push of a discrete button on the stick and it makes it easier to find the data once on the ground filtering through the data.
So will the beta be released this weekend or mid nov?
Well, my guess is since it didn't get released last friday, and now they are all at SEMA, we aren't going to see anything untill atleast mid Nov.Originally Posted by minytrker
A VPW Beta Release would have been really nice.Originally Posted by ringram
Agreed, Id say most units were still being used for vpw stuff anyway.
The V2 (and AutoCal) both have a real time clock that is used to generate timestamps on each logged frame. The clock is not battery backed, so it starts from 12 midnight each time you power up FlashScan. You can choose to have the PC set/update the clock in FlashScan to the correct time whenever it is connected via USB to the PC. That time is written to flash memory and used to (re)set the clock when it is powered up. So just before you unplug FlashScan from the PC to take it out and connect it to the vehicle you can "update the clock". Then the time will only be out by the number of seconds that it takes to go from the PC to the vehicle.Originally Posted by ringram
You can also set the time (and date) manually once you are connected to the vehicle.
The option to add "tags" to the log file by using the keys on FlashScan's keypad is also being implemented.
Yes, sorry. That's why I really wanted to get it out before I left. I won't be back in the office until mid Nov.Originally Posted by kbracing96
The first priority will be to finish off and package up the BB logging firmware for you guys to start breaking, I mean using.
