ok, this is the first time I have ever tried to edit anything on any car computer. Beyond total newb. I do see I need to find a "PCM Editing for Dummies" book as about half of this I was confused.
Anyway, this is my first attempt at the basic stuff, just to get the car to start and as few trouble codes as I can on first try. Id like for a few people to view what Ive done and tell me if they see something I missed, should have on, shouldnt have on, etc.
Details of car are below that I think are needed for review :
91 Camaro
350 block
810 swirl port heads
TPI intake unmodified
stock mangled exhaust
unknown non-roller cam with quite a bit of valve overlap(it lopes decently)
22lb injectors
dual electric fans
does have egr, map, maf, evap, purge, all hooked up.
t5 manual trans
3.23 rear axle
235/55/16 rubber
using '02 L31 van bin on the 0411 ecm.
car will be mostly intown stoplight to stoplight. Occasional hwy and 1000ft dashes.
things I know I played with:
1. vin code
2. speedo/axle/tire size
3. fans turned on, #1 kick on at 190,off 185, fan2 195/185
4. Class 2 theft off (later will attempt to connect to factory PWM)
5. post cat o2 sensors off
6. delete all automatic stuff, try to let it know its a standard
7. fuel tank pressure stuff off.
Do I need to make "B0104" cylinder volume 1000 rather then 713?
Since I'm standard, how does it know what gear I am in for rev limiter?
All help will be greatly appreciated!!
Dale
