Check out {B3632}
This will get you what you want.
You Can see that this parameter is eq ration based fuel sum.
So ben's should work here.
RAFNP and RAFIG should pull things into shape as well.
Cheers
Mick
Check out {B3632}
Cheers
Mick
Rev it up, Drop the clutch, See what happens?
open loop or closed loop?Originally Posted by MICK
also i don`t have this in the cal_link file.
lol if i add it will the RR make changes?
i am wondering if you can`t just make up your own links
if the RR is set up to change certain tables only.
well,
it did work.....BEN factor leaned it out,
so i am going 2 try to do this table manually.
