Results 1 to 9 of 9
Thread: Going from 00 to 02 operating system
    Oct 2007
    Default Going from 00 to 02 operating system
    So I got the upgrade for my cable, and successfully pulled the tune from my car. Presently I'm on my desktop and here's what I am doing:
    Downloaded a stock 2002 M6 Trans Am tune, and I am going through EVERY expandable folder, EVERY table, and copy/pasting everything to the 02 tune. Everything. Right now I'm at the Spark>General>Spark IAT Table and noticed something weird. My 00 tune has the columns in kPa, 02 has Grams/Cyl ??? How might I manage to swap over this table? Am I on the right track? I looked at the FAQ and am doing what I believe to be conveyed in there... Thanks.
    -J
    Jan 2007
    I think I had the same thing when I went to a 2002 os from a 2000 in my truck.
    I just used the new table with grams per cylinder. It should work just fine, but I don't know in a f-body.
    Jan 2007
    If you go one holdencrazy site you can download 99 to 02 stock stock file.
    http://www.holdencrazy.com/EFILive/modifiedTunes.php
    Oct 2007
    Thanks I think I see the one I need... does it very much matter that it is for an auto and i have manual? Or not really.
    -J
    Jan 2005
    transmission makes a difference. there should be one there for both A4's and M6's
    Oct 2007
    WOW sure enough two entries below is one for manuals... I should read everything next time :lol: thanks!
    -J
    Oct 2007
    Well I downloaded the stock 99 to 02 operating system, loaded it up, and am proceeding to transport my tables over. Ran into a snag on table B5911, Spark IAT Table. The X axis in the 02 is in Grams/Cylinder, my 99 is in kPa. I tried making a custom table and transposing, but they aren't similar units of measure. Any advice on how to take care of this? Thank you.
    -J
    Oct 2006
    As stated above, just leave it. It's not possible to tranpose every table equivalently, nor is it necessary. You'll notice that the 02 tune has tables in some cases not present in the 00 tune. These are interrelated with the settings in other tables in the tune. So I just left those in the 02 status.
    The list of tables you really need to switch over is actually pretty short.
  1. 09 lmm operating system
    By 07.5duramax in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: December 11th, 2009, 12:59 PM
  2. 02 operating system?
    By THEFERMANATOR in forum Allison 5 & 6 Speed
    Last Post: October 25th, 2009, 12:58 PM
  3. wrong operating system?
    By HighPSI in forum E37, E38 & E67 PFI ECM's
    Last Post: March 2nd, 2008, 02:08 PM
  4. operating system
    By ls1transam346 in forum Gen III V8 Specific
    Last Post: February 22nd, 2007, 11:49 AM
