Results 1 to 7 of 7
Thread: Silverado Question
    Oct 2006
    Lightbulb Silverado Question
    On a 2000 Silverado LQ4 is it possible to use a cos in this truck?
    And if so which one?
    90% of people are fools
    9% of people are somewhat smart and depend on the
    1% that know how to use EFIlive.
    Aug 2005
    Quote Originally Posted by Automotive Innovations
    Yes, you can. You actually have the option of using any of the COSs if you upgrade to a 2002 OS. There is a suitable OS to start from on holdencrazy. You'll need to go through the DTC list and compare the 00 to the 02, as there will likely be some generator circuit codes that need to be disabled.
    Justin
    Oct 2006
    Default Thanks
    Thank you for your prompt response!
    Jan 2007
    I just updated mine to a 2002os and youll have to get every idel table copied and pasted to the 2002os or it will idel wierd and high.
    When you said idle high, do you mean any time or at startup. I recently put an 07 6.0L in my 01 and when I start teh truck up it runs up to 1500 and then slowly comes back down to around 700. When I had the 4.8 in there I never noticed it going that high and wondering if it has something to do with the tune i had put on there. Is the reason to go to a 2002 OS basically summed up here? http://forum.efilive.com/showpost.ph...85&postcount=8
    The 2002 OS 12212156 lets you migrate to COS5 (TPS VE).
    Thanks, looks like I have some reading to do.
  1. Late 2007 - Early 2008 Silverado 6.0 SD Tune Question
    By Mike Norris in forum E37, E38 & E67 PFI ECM's
    Last Post: March 9th, 2010, 07:57 PM
  2. 2000 Silverado E-Fan Question...
    By GAMEOVER in forum General (Petrol, Gas, Ethanol)
    Last Post: December 29th, 2009, 02:13 PM
  3. 03 Silverado 6 Ltr
    By 03FullPull in forum Gen III V8 Specific
    Last Post: August 28th, 2008, 01:50 PM
  4. 06-07 Silverado SS
    By dirt_track_racer_81 in forum General (Petrol, Gas, Ethanol)
    Last Post: December 24th, 2006, 06:38 AM
  5. 06 silverado
    By HioSSilver in forum General (Petrol, Gas, Ethanol)
    Last Post: July 6th, 2006, 10:33 AM
