Results 1 to 4 of 4
Thread: buying another Vette PCM Serv. number differant?
    Lifetime Member mvvette97's Avatar
    Jul 2007
    Default buying another Vette PCM Serv. number differant?
    does it make any differance if the serv number on the pcm is differant than the one I have in the car right now? It came out of a 97 vette and that's the same year as mine.
    If it's the same year, it should be ok.
    Jul 2007
    is there a differance between the auto and manual pcm?
    Feb 2006
    The difference in just in the software. If you load yours in, it will match your car.
    Al
  1. buying a V1
    By barney28 in forum General (Diesel)
    Last Post: May 9th, 2010, 04:55 PM
  2. flash pinout? 05 ECM serv # 12591279
    By vectorbundle in forum General (Petrol, Gas, Ethanol)
    Last Post: July 1st, 2009, 02:55 AM
  3. Im intrested in buying EFI...
    By cowboy2844 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 24th, 2008, 05:22 PM
  4. I am buying Flashscan, I run 20 psi...... What map sensor???
    Last Post: June 3rd, 2005, 10:17 PM
