Thread: Logging E38 Specific PIDS W 08 Z06
    Oct 2003
    Default Logging E38 Specific PIDS W 08 Z06
    I am trying to log My 08 Z06 and I find when validating the PID's all of the E-38 specific pids are X out. The data that does show appears to be OK at idle, have not tried it on the road yet. Any ideas?
    Jim Wilson
    Feb 2004
    i have a probem when setting specefic pids that i want monitor....dashboard does not work and data does not seem to register....when i go to the e38 metric pids it works....still learning the program but it seems like there are a few bugs
    Oct 2003
    Default E38 Pids
    Vettemaster, I will try the E38 metric pid list. The reason I haven't already tried it is because it was only 18 channels and I thought we were to shoot for 24.
    Sanity check:
    - you entered the correct VIN/OS...?
    - you entered the correct controller type...?
    - you validated pids...?
    I pm'd Tech Support.
    Feb 2004
    Sanity check:
    i have entered the correct vin, controller and verified pids....when setting my own pids it doesn't work.....only works when i use the e38 metric setting...i have been able to add pids to monitor when using e38 metric but stiil have some issues...i cannot get ltft's cells....i do see ltft's when monitoring but cannot get them to display like i used to with my v6 version for my ls1...
    Some of the DMA PID's are not supported on the 2008 models yet, we'll get there....
  1. logging pids
    By aaronr in forum Black Box Logging
    Last Post: February 18th, 2009, 10:46 AM
  2. BB logging pids
    By fire0021 in forum FlashScan V2 BB Logging
    Last Post: January 30th, 2009, 11:47 AM
  3. Issues logging E38 PIDS
    By thunder550 in forum FlashScan V2 BB Logging
    Last Post: April 28th, 2008, 04:52 PM
  4. More PIDs in E67 for BB logging?
    By scdyne in forum Black Box Logging
    Last Post: January 30th, 2008, 11:22 AM
  5. Best PIDs for Logging Dry Shots?
    By Beer99C5 in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: July 23rd, 2006, 05:28 AM
