Results 1 to 10 of 17
Thread: Road Runner is frustrating me
    Junior Member billyjo's Avatar
    Oct 2006
    Angry Road Runner is frustrating me
    I got my RR a few weeks ago and decided that today would be the day that I put it through it's paces. I got everything dialed in and started driving, I didn't even get 2 blocks before I got the infamous "can't communicate" When I clicked "OK" my computer was froze until I removed the USB then everthing was good.
    I reset the whole thing and started driving again, went about 5 minutes and the exact same thing happened again. Went through the process again and guess what, same thing, I can't get it to run more than 15 minutes before it craps out .
    I'm running version 12.14R, on a Dell laptop running XP Pro through the USB port. Anybody have any input or did I get a bad RR?
    Bill
    72 K/5 4x4 Blazer, Radixed LQ4 with 3.2 pulley, WCCH 90mm TB, LPE GT2-3 cam, Stainless Works Headers, NV4500 5 speed, 14 bolt FF rear, Dana 60 front, 4.56 gears, detroit lockers, 4 wheel discs, Hydro brakes, full autometer gauges and more....
    Nov 2006
    check your drivers.
    are you using a USB hub?
    if you are i can tell you the RR doesn`t like to share a port.
    also if the USB cable comes out even a little it will disconnect.
    Lifetime Member Doc's Avatar
    Oct 2005
    How much ram and what kind of processor is on the Dell?
    www.efialchemy.com
    www.greatamericancarwar.com
    Oct 2006
    Thanks for the replys for far.
    I used the drivers from the tutorial so I think they are fine, and my laptop has 4 USB ports, the only other thing that was running off the USB was the flash scan. I'll keep a closer eye on the cable coming loose but I'm reasonably sure that's not it.
    It's got a pentium 1.73 porcessor with 2 GB of RAM.
    Any other ideas?
    Bill
    Jul 2005
    Does your cable have a choke on it? I have had issues with other products when using a chokeless cable.
    \"You Can Never Have Enough Horsepower\"
    Nov 2006
    check your latency timer, it should be 1.
    Oct 2006
    I checked the latency timer and it is set to 1, I had it ideling in the driveway this evening and there doesn't seem to be any rime or reason but it looses connection.
    Bill
    Nov 2006
    it maybe krunked.
    give moates an email.
    Nov 2006
    did you ever get this solved?
    Oct 2006
    Quote Originally Posted by mr.prick
    I haven't got this solved, I've sent 2 emails to moates with no response and I've called the place that I bought it from with no response (left messages no return phone call)
    If you've got any ideas why it's happening I'll be happy to entertain them, it's quite frustrating. It seems like if I get the message, unplug it, replug it back in (the usb) drive, get the message, repeat the step that after 3 or 4 times it's "good" until I turn it off and start it again.
  1. Need help with Road Runner ASAP
    By esco35m in forum RoadRunner Real-Time PCM Emulator
    Last Post: July 31st, 2007, 05:41 PM
  2. Can't connect to Road Runner
    By BlownAlaskan in forum RoadRunner Real-Time PCM Emulator
    Last Post: June 7th, 2007, 03:46 AM
  3. Road Runner DEAD????
    By Highlander in forum RoadRunner Real-Time PCM Emulator
    Last Post: October 13th, 2006, 04:12 PM
  4. 1998 Road Runner?
    By 1998ws6 in forum General (Petrol, Gas, Ethanol)
    Last Post: August 21st, 2006, 03:08 PM
