Results 1 to 10 of 12
Thread: Problem with V1--- Pics Inside...
    Default Problem with V1--- Pics Inside...
    Hey guys!
    Ive had my V1 for quite some time now... have tuned 8 Different trucks.
    I got in my truck getting ready to go to work and unhooked my V1 to put it my console along with the wires so it wouldn't be visible cause i travel out of town for several days at a time.
    Notice it was warm, but didnt think anything about it.
    I got back from a job and was going to tune my buddy's truck.
    I hooked everything up it wouldn't connect.
    After several minutes of head scratching i brought the V1 up to my nose and smelled the good ole circuit board getting hot smell...
    Pop the bottom of the V1 off and investigate... Its not pretty...
    Im not that knowledgeable about Circuit boards but i know a lil..
    From what i can see it appears a Resistor or something failed? and let full voltage go to the processor? and it over heated?
    I quickly ordered the V2 upgrade only to find out that the V1 has to be in operation to do update the V2 for it to be operable... So now im stuck with some expensive plastic boxes... haha..
    Ive gone through DC_Justin for help and he has emailed EFI Live.
    I have only used the Cables that came with the V1 and i Ohmed them out to check for a short between the connections to make sure it wasnt something that i personally did. .. i cant find anything.
    What do i do now??
    I suck at waiting also.......
    I know that EFI Live is at SEMA also so thats understanble...
    I would like to get this resolved fairly quickly.
    Thanks guys!!!
    Jonathan
    Lifetime Member Cougar281's Avatar
    Jan 2006
    I believe you'll get two VIN licenses with the new V2 so you should have no issue getting started. I don't think you HAVE to have the V1 for the upgrade, only to transfer the licenses from the V1 to the V2. I could be wrong though... I would imagine Ross & Paul will work with you on getting your licenses into the V2. They've always been great to deal with and are very understanding.
    I pm'd Tech Support.
    Thanks Joecar..
    I know they are busy at SEMA...
    And if you get the Upgrade V2, its inoperable if your V1 is broken.... you have to connect them together for everything to work...
    Jul 2004
    You need to send a message to sales@efilive.com or to support with both serial numbers and all your information and ask them to ask Donna how to get you the code you need.
    Donna said she'd take care of it tomorrow when she phones home if you've sent in all the info she needs.
    Ira
    Quote Originally Posted by Ira
    Ira
    So there is a way.... good... hahah
    Thanks guys!!!!!!!
    Just checking to see if you've got the necessary activations codes form EFILive to get your V2 working yet?
    Hey Paul,
    No i have not heard back from anyone as of yet.
    Thanks!
    Jonathan
    Aug 2005
    Yes you have, check your email.
    Just be very careful when you hook something back up to that truck, that has had a major failure with the supply voltage somewhere, it might be just be bad luck that a voltage regulator failed on the unit (there is two), but it looks pretty major to me.
  1. 4.5 dmax ecm pics
    By DURAtotheMAX in forum General (Diesel)
    Last Post: December 19th, 2009, 12:11 PM
  2. Idle Tuning w/ Pics for your viewing pleasure
    By kwhiteside in forum Gen III V8 Specific
    Last Post: July 22nd, 2009, 02:31 AM
  3. Pics and a short idle video of 'The Biscuit' after waking from her coma
    By ArKay99 in forum General (Petrol, Gas, Ethanol)
    Last Post: March 7th, 2008, 06:16 AM
  4. EFILive Sticker Pics ;o)
    By kbracing96 in forum Lounge
    Last Post: April 11th, 2007, 09:39 AM
  5. 2bar sensor pics - 12580698
    By SS2win in forum General (Petrol, Gas, Ethanol)
    Last Post: September 3rd, 2005, 01:14 PM
