Results 1 to 3 of 3
Thread: how long until an e67 custom os solution?
    Oct 2007
    Default how long until an e67 custom os solution?
    I am waiting on one for a 10PSI project on the E67 controller. I have talked to a couple nice folks on the forum waiting on the same thing. Anyone have a timeline?
    You could do it right now if you wanted. All E38 & E67 controllers support boost from the factory.
    Aug 2004
    Quote Originally Posted by GMPX
    All you need to do is dump in a 2 or 3 bar map, fix the map scaler, and then start modding efilives Virtual ve table using the 2 or 3 bar map table. It is very easy and works wonderfully.
  1. 96-02 vortec intake solution
    By CC&M in forum Gen III V8 Specific
    Last Post: February 6th, 2009, 04:37 PM
  2. Update and solution to 98 PCM connection problem
    By eurospec1 in forum FlashScan V2
    Last Post: December 20th, 2007, 11:45 AM
  3. COS3 cold lean startup solution
    By Whippled 496 in forum Custom Operating Systems
    Last Post: January 28th, 2007, 06:50 AM
  4. Temporary IAT Sensor Solution to 5 Wire MAF
    By S10Wildside in forum General (Petrol, Gas, Ethanol)
    Last Post: October 8th, 2006, 01:29 PM
